O2 sensor grommet
Old May 1, 2012 | 02:42 AM
LADave's Avatar
O2 sensor grommet
On an '88 SR5 4x4 with 22RE I have just replaced the O2 sensor with a Denso unit that I bought on eBay instead of from Toyota. It came without a grommet for the gaping hole under the driver's seat. Is there a preferred way to plug that before fording rivers, or splashing through puddles anyhow?
Old May 1, 2012 | 08:23 AM
snobdds's Avatar
O2 sensors, even dealer supplied ones, do not come with that grommet. You will need to order a new one from the dealer.
Old May 1, 2012 | 08:38 AM
LADave's Avatar
I have the old grommet in decent condition still on the old sensor wires. I could easily snip the wires and take it off, but then forcing the new connector through the grommet's aperture would be like a gerbil giving birth to a hippopotamus.
I was thinking of resorting to a gob of silicone sealer unless someone comes up with a better way.
Old May 1, 2012 | 09:04 AM
xylicon's Avatar
When I bought my 02 sensor from Toyota is came with a new grommet ready to go...
Old May 1, 2012 | 09:23 AM
snobdds's Avatar
Later models have the connection that does not go through the floor board. So I guess it depends on what year you have...
Old May 1, 2012 | 05:23 PM
LADave's Avatar
Finally figured it out. You can unclip each terminal pin from the connector body with a probe-type tool. Then pass just the four wires through the center of the old grommet and reassemble the connector.
Obviously you need to keep careful track of which individual wire goes where.
moparbay
Mar 10, 2023 03:50 PM
jb451
7
Oct 7, 2022 06:58 AM
Kreedy1
Sep 8, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
moparbay
Sep 3, 2015 12:48 PM
