Power Steering Question *Pics*
Old May 24, 2008 | 04:41 PM
Hyperwrx's Avatar
1986 Toyota Truck 4x4 w/ 22re- Not sure if this is the engine that came in the truck. I am nowhere close to the first owner. I am a novice mechanic but want to learn the ins and outs of my truck so I'm attempting to put it in myself.
Purchased a power steering system from individual. He said it would work in 86 thru 89 4Runners and 86 thru 88 4wd trucks.
In my pictures below do the red arrows indicate the bolts that hold the power steering pump onto the engine block? If so they don't correctly align up with the pump I purchased. It pushes the pump pully out way too far forward of the pulleys on the harmonic dampener plus really doesn't align the bolts up correctly. (excuse the oil mess, oil pump seal went out and it's a mess currently).
Any help would be appreciated.
Am I on the complete wrong side of the engine?
Old May 24, 2008 | 04:50 PM
slacker's Avatar
no ..
there is a bracket that holds the pump ...
Old May 24, 2008 | 05:06 PM
Hyperwrx's Avatar
I am thinking I am on the wrong side of the engine entirely. I see pictures of the pump sandwiched between the distributor and the alternator.
Example below. (Not my truck obviously)
Old May 24, 2008 | 05:21 PM
4Crawler's Avatar
As noted, there is a bracket, it and the p/s pump mount under the distributor here:
The bracket is the green item in the picture below:
Old May 24, 2008 | 05:25 PM
Noltz's Avatar
Yep. Found this on Google;
http://www.webercomputing.net/~awebe...e%20before.JPG
Sheitty pic, but you can see the PS pump (in all it's rusty glory) mounted to the drivers side of the motor.
Old May 24, 2008 | 05:34 PM
Hyperwrx's Avatar
Thank you very much guys. Appreciate it
Old May 24, 2008 | 05:35 PM
just a 22re's Avatar
yep and good luck on getting that mount on there.......... it really does suck it took me an hour to finger that one out you have the alt and power s mounts plus you gotta get them over the water pipe it was hard and i did it on a engine stand then i got it lol yeah its easy but yet i had the alt braket on and that was hard long story short...............
take off the alt, the alt bracket then bolt the ps mount and then the alt mount i be leave i think im right but cant remember i did it at about 4 in the morning and that was working all day and then all night i was tired have fun its not that bad or hard to do it
glowz825
Jan 25, 2022 09:28 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
keithporter83
Jul 24, 2015 07:37 AM
jon.r
Jul 11, 2015 03:34 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
