help now PLEASE!!!!!
Old May 28, 2008 | 08:28 PM
toyotarunner92's Avatar
i just replaced all the o-rings on the injectors and put everything back together manual spec. and now it starts, but the "check engine" light comes on and then it suddenly shuts off.
i would take it to checker or autozone to get it diagnosed, but i cant get it there. DOESS anyone have any suggestions for me?
the fuel pump is fine and i am jsut not sure what could be wrong...
help me please!!! -_-
Old May 28, 2008 | 08:52 PM
4Crawler's Avatar
It is trivial to pull the error code(s) yourself:
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old May 28, 2008 | 09:10 PM
Kaydon's Avatar
did you try and purge the system with the injector out to make sure fuel is flowing through them properly?
Old May 28, 2008 | 10:31 PM
apalmer1's Avatar
more info, is this is a problem that just started after you replaced the O-rings, or was it already doing this beforehand?
Old May 29, 2008 | 06:26 AM
InternetRoadkill's Avatar
Sounds like the injectors aren't firing and that it's starting using the cold start injector only. Is everything plugged in right?
Old May 29, 2008 | 04:23 PM
wow ok so i have got to be the stupidest kid alive....
um the prob was the MAF sensor... i forgot to plug it in. i still do have a vaccuum leak tho. my truck works great and a lot smoother after a thorough cleaning of the injectors and what not.
sorry for the stupidity...
thanks guys and girls
Old May 29, 2008 | 05:35 PM
76ANTHONY's Avatar
lmao, hey at least you found the issue and it was no huge problem
Old May 29, 2008 | 06:06 PM
82yota's Avatar
Thats not as bad as I have done with my plane and when starting it forgetting to push the mixture back in haha. And mine isn't electric start so I was shoving on it for a while before I realized that.
