22r=22re?
Old Oct 22, 2007 | 03:05 PM
GT88Yota's Avatar
22r=22re?
I have an '88 pickup with a 22RE which needs a total rebuild. I found a low mileage 22R engine out of an '84 pickup and I was wondering if I could use the 22R block/head with the 22RE intake/electrical stuff.
Has anyone done this or heard about it being done?
Old Oct 22, 2007 | 03:34 PM
84sr5yoty's Avatar
The head from the 84 will need the bosses for the EFI intake manifold, and a non-EFI head WILL NOT have them. The answer, unfortunately, is no.
Old Oct 22, 2007 | 03:50 PM
notanymore's Avatar
arnt the 22r's from84 and earlier different that the 85+ ones?
Old Oct 22, 2007 | 04:00 PM
GT88Yota's Avatar
I was reading through the following links and it looks like late '83 and 84+ 22R heads have bosses for the EFI stuff.
http://www.pirate4x4.com/forum/showthread.php?t=316661
http://www.babcox.com/editorial/ar/ar119838.htm
superjoe83's Avatar
umm, 84 is a goofy year, they have the older style head/block BUT the head IS drilled and tapped for the EFI intake, the block doesn't have the knock sensor hole, but you can weld a nut on the motor mount to attach the KS....
Heres proof, my 84 4runner converted to EFI
Old Oct 22, 2007 | 04:03 PM
GT88Yota's Avatar
Superjoe, so you've done it? Any problems you ran into or was it quick and painless except for welding the nut on the motor mount?
Old Oct 22, 2007 | 04:08 PM
superjoe83's Avatar
ya i did it to my 84, everything bolted up fine, just make sure the motor that you getting is drilled for the EFI intake, just in case its not really an 84 motor, the only thing you will have to change is the knock sensor location, i just took the sensor to a hardware store and found a nut that threaded on, then i welded the nut to the front of the passenger side motor mount, since your truck is already EFI you wont have any of the wiring hurdles that i had to overcome, other than the knock senor it should be a direct swap
Old Oct 22, 2007 | 04:10 PM
GT88Yota's Avatar
How can I tell of the head is drilled for the EFI intake?
Old Oct 22, 2007 | 04:22 PM
superjoe83's Avatar
here, first one is a older head and is not drilled, 2nd one is a EFI head
Old Oct 22, 2007 | 04:23 PM
GT88Yota's Avatar
thanks for the help! is the bottom pic what your 84 head looked like? Not only the holes but the water passage in the middle?
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
cars-guy
Jul 11, 2015 07:51 PM
87blyota
Jul 10, 2015 04:31 AM
