Hard to get I gear sometimes
Old Nov 22, 2012 | 05:30 PM
7273rogers's Avatar
I am new to this forum but have been reading and love the comments. My question is I have a 91 toy truck 4x4 and the clutch when mashed in feels like it is still wanting to go and it is hard to get in gear sometimes after you put it in neutral is this the clutch or slave cylinder . Thanks for any ideas
Old Nov 22, 2012 | 05:37 PM
Russmoe's Avatar
Seems pretty common most of the toyotas I've owned have done it especially in reverse I think they even mention the issue in the owners manual usually if u disengage the clutch then try again it will go in gear
Old Nov 22, 2012 | 06:07 PM
7273rogers's Avatar
Yes ,reverse is a little hard to get in gear it wants to grind but the feel of the clutch wanting to pull when it is mashed in is what I could not understand
Old Nov 22, 2012 | 06:26 PM
Russmoe's Avatar
Is the fluid level good in the reservoir? It sits on the drivers side fenderwall
Russmoe's Avatar
Firewall*
Old Nov 22, 2012 | 06:32 PM
scope103's Avatar
https://www.yotatech.com/forums/f116...engage-261536/
Old Nov 22, 2012 | 07:03 PM
7273rogers's Avatar
Fluid is good and tomorrow I will check clutch pedal bracket
Old Nov 22, 2012 | 07:44 PM
bob200587's Avatar
Sounds like master to me. I've gotten a couple of duds when replacing it before, so I've been through it a few times.
Check under your carpet to see if there's any fluid or rust on the driver's floor, could be a small leak that has gone unnoticed.
Could be an issue with synchronizers possibly too. I'm not as familiar with that.
Old Nov 24, 2012 | 10:10 AM
WHEELER8688's Avatar
I had a problem like this and turned out it was just the clutch pedal rod needed to be adjusted
Old Nov 24, 2012 | 10:34 AM
silsbeeboy88's Avatar
Mine was doing that and i noticed a small leak at the slave cylinder changed that and fixed the problem
Old Nov 24, 2012 | 08:50 PM
Chip N Sawbones's Avatar
You don't have to remove anything to check the clutch pedal bracket, so that should be the first thing to look at. I had the same clutch problems you've got and the bracket was the problem.
Old Nov 24, 2012 | 09:26 PM
dropzone's Avatar
Fossilized
https://www.yotatech.com/forums/f116...fatigue-32667/
young buck
18
Aug 27, 2018 02:40 PM
Scotto6591
Sep 1, 2015 03:24 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Backcountry411
Jul 24, 2015 08:06 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
