backfire and no start
Old May 10, 2007 | 09:57 AM
brentcole5's Avatar
91 backfires and tries to start after replacing motor and changing distributor. im completely out of ideas
Old May 10, 2007 | 10:05 AM
brentcole5's Avatar
by the way its a 3vz with 140k
Old May 10, 2007 | 01:21 PM
DudeBud's Avatar
sounds like the dizzy is off 180..
Old May 12, 2007 | 01:30 AM
the_supernerd's Avatar
I would say that either the distributor is 180 off as posted above, or the spark plug wires are not in the correct order.
Old May 12, 2007 | 01:36 AM
DeathCougar's Avatar
its 180 off. Remember it has to be at 0' at TDC on the Compression stroke for intitial time.
Old May 12, 2007 | 03:30 AM
tnau664's Avatar
I just went through something similar. Be sure the cam is in time with the crank gear. Turn to tdc, then check the top.
Good Luck
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
