1988 4 runner that needs help please
Old Sep 26, 2007 | 03:32 PM
pat24's Avatar
my truck wont start so the first thing i did was pull the cel codes by jumping the ports i just want to know if these things are dead will it cause the truck not to start i got 3 problems
1. THROTTLE POSITION SENSOR SIGNAL--OPEN OR SHORT IN TPS SIGNAL
2.IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
3.INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
please help me the codes again are 24, 41,51 thanks if any one can help it would be great
Old Sep 26, 2011 | 05:26 PM
86carbPU's Avatar
I got the same code 51 on 88pickup too. I ended up finding out that the IDL-E2 within the TPS wasn't working. I've still to find out what caused it to fail but I'll try to trace the wires back to the ECU & do a voltage check & post the results, if it helps.
Here's the resources I've been using for the TPS:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
http://personal.utulsa.edu/~nathan-b...e/102engin.pdf
http://www.autoshop101.com/forms/h33.pdf
You can get the Factory Service Manual @:
http://ncttora.com/fsm/index.html
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
