22re oil pump
Old Oct 18, 2006 | 09:02 AM
cweich's Avatar
22re oil pump
Have an 1985 22re that i am working on, and i want to test the oil pump, is there a way to prelube this engine??? also is it common for an oil pump to go out on these motors.
Thanks
Old Oct 18, 2006 | 09:10 AM
EWAYota's Avatar
you can pack the oil pump with vasoline.
Old Oct 18, 2006 | 09:31 AM
cweich's Avatar
As a way to see if it is working or to prelube? Thanks for the respone
Old Oct 18, 2006 | 09:48 AM
EWAYota's Avatar
Prelube. Not sure how to test it without having it bolted on and starting the engine. From reading your other thread, sounds like your doing a teardown? If that is the case, might as well just get a new one and not worry about it.
Old Oct 18, 2006 | 12:15 PM
dougm395's Avatar
definatly pack w/ petrolium jelly
Old Oct 18, 2006 | 02:07 PM
dcg9381's Avatar
There's no way to measure volume short of a major ordeal...
Just check to see that the spines on the pump itself and drive are not worn.
They're cheap.. Honestly, I replace them when rebuilding, but for minor stuff - like heads/front covers, I wouldn't worry about them unless you're having oil pressure issues.
Prelube as mentioned above. On rebuilt motors, I've seen the pumps not prime without being pre-lubed.
Best way to check it is to pull the plugs and turn it over until you register (or see) oil pressure.
Old Oct 18, 2006 | 03:10 PM
millertime_t1's Avatar
I tells how to check an oil pump for wear using a feeler guage in Haynes service manual -- but i'm not sure about the details
Old Oct 18, 2006 | 06:05 PM
toyaholic's Avatar
get a new one.
Old Oct 18, 2006 | 06:54 PM
yota_krazy's Avatar
x2 on checking with a feeler guage. No need to replace it if it aint broke
bigjstang
Jun 2, 2025 03:56 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
