Dash lights will not dim
Old Mar 12, 2023 | 12:17 PM
4-Max's Avatar
I have a 1989 4Runner. My dash lights stay on at the same intensity even when rheostat is adjusted. I have tested the rheostat and it ohmed out correctly (infinity-7-0). Even when I remove the rheostat, the lights remain on at the same intensity. I am assuming the rheostat has been bypassed but I do not know how to troubleshoot the issue or where the problem could be. The RRunner is stock and have not added or rewired anything. Anyone had a similar issue or a fix?
Old Mar 12, 2023 | 05:36 PM
jgrant721's Avatar
Here's the schematic for the 90-95 4Runner. I don't imagine it changed much from 89. You can see the rheostat near the bottom center. I sketched in what I think the rheostat is doing.
You should be able to check the wiring and see if the indicated fuse (15A Taillight) affects the dash lights. If your wire colors don't match the drawing it may be more challenging!
Good luck
Jim
90-95 dash lights
Old Mar 22, 2023 | 09:53 AM
4-Max's Avatar
Thanks for the diagram. I was able to track down the diagram for my year, see attached. Again, I have removed and tested the rheostat and it is to spec. The lights remain on when the rheostat is removed so it appears something is bypassing the rheostat. I have no clue.
Old Mar 22, 2023 | 05:34 PM
jgrant721's Avatar
Have you checked that the ground lead from the rheostat actually goes to ground? It won't do anything if it's not grounded.
Old Mar 23, 2023 | 08:15 AM
SomedayJ's Avatar
Led lights?
Old Mar 28, 2023 | 10:29 AM
4-Max's Avatar
Not LED, the have made no modifications to the interior lighting system.
Old Mar 28, 2023 | 11:38 AM
scope103's Avatar
If the dash lights remain on at all with the rheostat removed, that means the R-B wire (pin 2) in your diagram is grounded somewhere. (You can turn the lights off and check that with a test-light or multimeter, but you can trust me on this.) It could be as simple as a short in the rheostat socket (pin 1 to 2). Since R-B is grounded all the time, a multimeter will be little help finding the "bypass." Instead, you'll either have to carefully inspect the wiring, or go as far as (for instance) cutting the W-B wire from the rheostat (if the lights go off, that means the socket itself is shorted. So now you need a new socket, and you have to repair the wire you cut.)
Tugs
Jan 19, 2014 04:52 PM
truckdude239
Sep 6, 2009 10:20 AM
TRunner
10
Jan 11, 2005 08:41 AM
