Error 52, won't run
Old Jan 19, 2023 | 03:36 PM
RosieHeart's Avatar
Error 52, won't run
I have an 89 Toyota pickup, the 3vze efi. It has about 400k miles. I recently replaced the fuel line to the cold start injector and the fuel dampener after a leak developed under the intake manifold. I am in Alaska.
Last night (about ten below) I went to start it. It had been running 8hrs prior and was plugged in. After starting up great and running for a few minutes it sounded like it wasn't receiving enough fuel. I ran back, gave it gas, it still died when I took my foot off the gas. Started up again just fine. Gave it plenty of gas. Back fired. Wanted to stall out when I took my foot off the gas. Wanted to flood out if I gave it gas. Each time I started it the time it would run was progressively shorter. Currently it turns over and "catches" but doesn't run. It has a code 52. Where should I start?
Old Jan 21, 2023 | 07:28 AM
Jimkola's Avatar
YT Community Team
5 Year Member
A knock sensor code shouldn't stop it from running.
Fall back on the basics. With spark, fuel, compression, and reasonably close timing you have internal combustion.
Confirm spark, then check fuel.
-10. Damn. I pray you have a heated garage
Old Jan 21, 2023 | 03:59 PM
RosieHeart's Avatar
It's flooding out on start up. Assuming cold start injector. Did a test doesn't seem to be fuel pressure regulator.
Old Jan 21, 2023 | 04:21 PM
scope103's Avatar
What test? Are you sure you have the vacuum plumbing correct? (Check the under-hood sticker.)
The CSI is trivial to check. Remove the whole CSI from the intake plenum (do NOT remove the fuel line; you'll have to replace the two crush washers if you do). Pressurize the fuel system by jumpering FP to B+. Any drips? Reinstall the injector and disconnect the electrical connector. Any change on start-up? If not, it's not your CSI.
Old Jan 22, 2023 | 06:41 AM
RosieHeart's Avatar
You're right, my friend who's driveway it died in pulled the CSI plug and it didn't make a difference. Where would you start?
Tanker5503
Mar 6, 2022 12:51 PM
Schnayke
Feb 5, 2012 04:16 PM
Trinok
Jan 3, 2008 04:50 PM
AKennedy87
Jul 13, 2006 04:52 PM
