Redline MT-90 or 75W-90
Old Feb 13, 2008 | 05:20 PM
RBA's Avatar
RBA
Questions for those who run it. I will be using the mt-90 on my 5 spd transmission but could I use the same for the transfer case and differential or do I need to switch to the 75W-90 gear oil for those? Thanks for the input.
Old Feb 13, 2008 | 05:46 PM
Keith B.'s Avatar
MT90 is GL-4 spec: good for trans and tfr, but diffs require GL-5---75W90, 80W-90, etc. Hint: If you are daily driving in 2WD(like most of us), change rear diff oil more often, even with sythetic GL-5.
MMA_Alex's Avatar
Aren't a whole lot of people running mt-90 in the t-case, but it should be fine. You'll love it in the trans. Its like night vs. day when the trans is cold.
Old Feb 14, 2008 | 12:54 AM
Matt16's Avatar
I put MT-90 in my transmission and it truly is night and day. Could be my imagination, the full benefits came after a couple days.
Before MT-90 it was hard to engage 2nd gear often. Afterward it felt butter smooth. One of the best mods I've done.
Old Feb 14, 2008 | 04:10 AM
MMA_Alex's Avatar
For me it took a fair amount of force to get it into 2nd on cold mornings unless you drove in first for a mile or two to let the oil get moving. With the mt-90 it goes right into 2nd even when cold with no issues. It also shifts smoother than before, but its way more noticable when cold.
and yeah im sorry i missed the diff part of your question. the gears in the diff are under more pressure, and so you want a gl-5 (extreme pressure) lubricant.
Old Feb 14, 2008 | 12:46 PM
Matt16's Avatar
wonder what's up with second eh?
Old Feb 14, 2008 | 12:50 PM
MMA_Alex's Avatar
im guessing syncro wear since 1/2 are the most used gears, but generally you're not moving when putting 'er into first
Old Feb 14, 2008 | 04:50 PM
Squeebs's Avatar
Amsoil severe gear 75-90
and then forget about it.
kazuya2416
Apr 5, 2024 02:17 AM
he's gone
7
Dec 3, 2019 07:08 AM
Pri$erulz
Nov 17, 2019 08:03 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Bob_98SR5
24
Mar 2, 2004 09:33 PM
