Injector installation - no engine oil on the o-rings?
Old 02-07-2008, 10:48 AM
runethechamp's Avatar
Posted this question in my rebuild thread, but with no responses I'll make a separate thread for this.
Why is it that the FSM specifies and emphasizes to NOT use engine oil on the o-rings during injector installation. I see witchhunter says you can use that, but I haven't been able to figure out why the FSM has that statement in there. Any injector specialists out there who knows the answer to this?
Old 02-07-2008, 03:10 PM
mr toytech's Avatar
engine oil will swell the injector o rings. i think they say to use petrolium jelly on them.
Old 02-07-2008, 03:20 PM
mr toytech's Avatar
i will correct myself, it says to apply gas to them before installation. not petrolium jelly. but as i said before engine oil will swell the orings causing them to leak or tear after installation.
Old 02-07-2008, 07:43 PM
weakyota91's Avatar
i used motor oil seems to be fine i dont think its that big a deal. Or just use gas to be on the safe side
Old 02-07-2008, 10:43 PM
gametom's Avatar
petrolium jelly is the way to go
i tryed twice with gas and had leaks
Old 02-08-2008, 12:56 PM
shaeff's Avatar
i just did mine after i got my injectors cleaned. used petroleum jelly. did the same on the supra, no issues with either thus far.
Old 02-08-2008, 01:42 PM
Blurr's Avatar
i didn't use anything. so far 4k+ miles and no leaks.
Old 02-08-2008, 01:53 PM
I read something somewhere where they suggested that the note in the FSM is a product of a bad translation. Even witchhunter suggests engine oil on their website, so I guess it can't be that bad. I hope it's not since I discovered the note in the FSM after I had installed the injectors using engine oil
Yont283
09-23-2022 08:06 PM
voiddweller
19
05-02-2016 09:10 PM
WI Girl
06-25-2015 03:45 AM
Mohamed
17
08-21-2002 12:54 PM
Quick Reply: Injector installation - no engine oil on the o-rings?
