wwhat type of lift is this????
Old Mar 17, 2010 | 03:55 PM
8yota6's Avatar
hey i am pretty new to 4x4's in was just wondering if anyone knows what kind of lift this is?
Old Mar 17, 2010 | 04:01 PM
BackGateYota92's Avatar
Wow that looks kinda odd. its like its some kind of weird lift block. lol i would like to know what that is also.
SpecialScottie's Avatar
Those look like stock springs with an add a leaf. And them some kind of home made block on the bottom
It looks like its extended out to reduce axle wrap
Old Mar 17, 2010 | 04:02 PM
2DoorRunner's Avatar
wth?
I have never seen anything like that before. Looks sketchy to me.
Old Mar 17, 2010 | 04:04 PM
i cant really see how that would reduce axle wrap though?
Old Mar 17, 2010 | 04:06 PM
Yeah it looks like it would limit flex alot.
Maybe some sort of bump stop?
Old Mar 17, 2010 | 04:08 PM
8yota6's Avatar
thought it was weird also. i looked at tons of lift kits and knone of them lokked like what i got. maybe i'll look into a real lift kit. any recommendations?
Old Mar 17, 2010 | 04:12 PM
well by looking at your truck i assume you have a 4" drop bracket lift and 3" body lift right??? so i guess any 4" leaf pack would work. your truck looks beast btw. i love the whole wide tire look. what size tire and rims you running?
Old Mar 17, 2010 | 04:15 PM
8yota6's Avatar
33x15.50x15/ thx
Old Mar 17, 2010 | 04:18 PM
your rig looks real mean for sure. lol as far as lift though you might be able to put some chevy springs and a shackle or add a leaf. i think that should net you around 4 inches of lift give or take
Old Mar 17, 2010 | 04:23 PM
akaphilly's Avatar
looks like you have an add a leaf and that block. i would ditch that and get some f150 springs or trail gear.
oh ya... nice bald tires !
Old Mar 17, 2010 | 04:31 PM
8yota6's Avatar
yea in the process of looking for new tires
Old Mar 17, 2010 | 04:51 PM
you gonna keep the fat stance??? haha
Old Mar 17, 2010 | 04:55 PM
b4wheeler's Avatar
That is called a "traction lift".
There were sold many, many years ago....
Funny thing is, they are on backwards....
They are designed to be traction bars and lift block in the same unit......
http://www.gotojeepaccessories.com/w...ction_lift.asp
TRACTION LIFT
Acts as a lifting device and as a traction bar. Warrior traction lift is a fully adjustable traction bar to help preload all your traction needs. The traction lift replaces your 2 1/2" lift block or can be used as a 2 1/2" lift for added ride clearance. The system mounts between your leaf spring pack and your differential housing, with the main bar pointed forward, on the rear end housing of your vehicle. The vertical "U-shaped" bars extend above the leaf spring where two cross pins are installed. The traction lift system is not designed to be used in the front of the vehicle. If you are not replacing lift blocks when you install your traction lift, you will need longer u-bolts
Old Mar 17, 2010 | 04:57 PM
Dang thats weird. i guess its not useless after all??? lol
Sep 4, 2015 09:27 AM
mistershmi
Aug 31, 2015 03:44 PM
Ernie217
Aug 14, 2015 05:25 AM
Poppie51
Aug 2, 2015 11:29 PM
coffey50
Jul 28, 2015 10:55 AM
