Check engine light only comes on at speed
Old Feb 13, 2007 | 08:38 AM
bad_brains's Avatar
Took my recently aquired 22re for a interstate jog, and found that the check engine light will pop on at speed (over ~55 mph). It didn't come one until about 10 minutes of riding at this speed. Nothing appears wrong in the dash dials as far as overheating is concerned. Then when I backed off down close to 50 mph and below, the light went off.
Am I correct to assume that the diagnostic system will not indicate a problem unless the check engine light is on full time?
Any ideas or similar experiences??
Old Feb 13, 2007 | 08:48 AM
maxpower_hd's Avatar
No. The ECM will, or at least can, hold codes without the CEL actually being on. Do you have a manual? Jump the same two connectors in the DIAG box that you would to check the timing. Then turn the key on and count the blinks.
Here is a link from the manual: http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
Old Feb 13, 2007 | 08:57 AM
4runnerx3's Avatar
Mine came on at a certain speed, it was the o2 sensor.
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
