22re is driving me nuts
Old Feb 7, 2007 | 05:24 PM
yotaboy66's Avatar
just got the motor in leak like a ĊĊĊĊing siv from one of the front seals idk which throw me some ideas and the cold start sensor is weird very low radiator pressure not leaking or burning i dont think mainly the oil lewak and what should you look out for if u have a blown head gasket
thanks
Old Feb 7, 2007 | 05:27 PM
dcg9381's Avatar
One problem at a time... LEaking oil or water?
Old Feb 7, 2007 | 06:04 PM
seanz0rz's Avatar
Guest
woah, breath man!!!
ok, so you are leaking oil out of one of your front seals, but you dont know which one.
in addition to that, the cold start sensor is weird (not sure what that means)
you have a very low radiator pressure, but you think its not leaking or burning up in the cylinders.
what are the symptoms of a blown head gasket.
hope that makes it clearer for those who respond with helpful posts to this thread.
Old Feb 8, 2007 | 11:11 AM
surf4runner's Avatar
oil? from the front seal/oil pump?
a rebuild? 22RE just installed...because...
a new seal replacing the old may cause leaking as the old seal has worn a pattern onto the crank. get another seal that seals against a new spot on the crank.
mskalmus
May 28, 2017 07:51 AM
Whatever123
Sep 30, 2015 12:12 AM
Sep 4, 2015 09:27 AM
redneck17
Jul 17, 2015 07:44 PM
Cdn-wilderness
Jul 10, 2015 07:43 PM
