92 Toyota PU 3.0 LED Turn Signals
Old Aug 27, 2018 | 11:49 PM
Washington Rebel's Avatar
Exclamation 92 Toyota PU 3.0 LED Turn Signals
ok. so i ordered LED replacement bulbs for my turn signals. rear signals work fine however plugging the bulbs into the front sockets they do not work at all. all bulbs work just fine. yes i have a load resistor installed even with the load resistor the bulb does not even turn on. my question is. how the hell do i get them to work up front? as far as i can front light wiring is all good with no problems. if i use the regular bulbs they work fine. im at a loss and need help.
Old Aug 27, 2018 | 11:59 PM
wyoming9's Avatar
Red face
Led bulbs have polarity they only work installed in one direction
If you have a extra socket reverse the wires see if they light
have you tested that the bulbs work ??
I have had so much bad luck with the led bulbs I now just only use the lights .
pdyebrasil
19
Oct 15, 2018 07:40 PM
onmyway
Aug 4, 2016 12:57 PM
limon32
Nov 17, 2009 07:57 PM
Yota Tony
Feb 26, 2007 03:47 PM
Mig750
13
Jun 13, 2005 08:47 PM
