Front Power Windows not working
Old Aug 30, 2018 | 04:34 AM
Taos's Avatar
Exclamation Front Power Windows not working
The two front power windows will not work. The rear windows work but only using the switch on the back door itself. The main switch on the drivers side door will not work the back windows. Everything else works fine. Before the windows stopped working, they were intermittent. I tried a used master switch from eBay and that didn't fix the problem. This is a 99 4runner
Old Aug 31, 2018 | 12:27 AM
wyoming9's Avatar
Red face
Time to break out the Meter after years the wires coming out of the drivers door tend to break
I test the drivers side motor first.
find why that one does not work then onto the right side
The Master switch needs to be connected at all times for the right front and two rear windows to work
I have worked on some older 4Runners that would only have the windows work with the engine running or a battery charger hooked up
pendrag
7
Jan 22, 2013 11:07 AM
cbettez
Jul 27, 2011 01:41 PM
thor99
May 28, 2010 07:22 PM
A.Wilson013
Sep 24, 2009 06:01 AM
Bubba Wilks
May 27, 2008 09:17 PM
