Battery and Brake Light stays on
Last night I flushed my heater core and I think I shorted something out. After the flush, I drove around for a bit and the Battery and Brake lights came on (see pic)
1994 Pickup
22RE
Any suggestion how to fix the problem?
lights
1994 Pickup
22RE
lights
As Discombobulated suggests, put your multimeter right on the battery posts. You should get about 12.6v with key-off, and about 14.1v with engine-running.
Don't try to diagnose this without a multimeter. They're cheaper than dirt, and they are the only tool that works.
I am going to take off the alt and change the regulator and brushes. It's the OEM ALT so very likely the problem. I'll also take a reading to see if I am on the right track.
Thank you Toyota gurus.
Okay, now what? You could just replace the alternator on the blind. There's a chance that will fix your problem, and if it doesn't, you're only out $125 or so.
Or, you could check the voltage at the alternator output (fat wire). And check the excitation voltage (red wire; should be battery voltage with key-on). If you have no output but do have excitation voltage, most auto parts stores (O'Reilly's, Autozone) will test your alternator "for free." (They want you to buy the replacement there.)
The following users liked this post:
1994Toyota4X2 (10-18-2018)
Aleeex_u
06-05-2016 06:52 PM
gary96360
01-05-2011 06:53 PM
