Speedo cable gear?
Old May 18, 2009 | 08:51 PM
1990mudslut's Avatar
Speedo cable gear?
Hey all,I just got a new sr5 cluster for my truck since all my guages were shot to hell and back.Anways I noticed that the speedo is slower than my last one.My last one wasnt very reliable either most of the time it was stuck at 30 haha.So I just checked the converter on 4crawler.com and his clculator feels about right im guess I truly am running around 55 when the speedo says 45.I have 31x 10.5s on my truck and stock 4:10s.
ok ok enough rambling I need to know where to find toyota cable gears so i can correct my speed.I have searched the net for a hr or two and no luck at all.
Or myabe you guys have another way to fix it?idk I just would like to get it fixed up
Old May 18, 2009 | 09:09 PM
INFINITY's Avatar
are you sure you have 4.10s? have you checked your axle code?
hell just put a gps on your dash and read it for your speed.
Old May 19, 2009 | 09:28 AM
Yup im positive i have 4:10s,I just want a real fix for it which is the gear but i can't find one.
how hard do yall think it would be to make one?
Old May 19, 2009 | 10:13 AM
mt_goat's Avatar
How many teeth do you have now? I've seen 18 and 20 tooth gears.
Old May 19, 2009 | 10:18 AM
4Crawler's Avatar
Might also check with a local speedometer shop. They can build you up a calibration gear box to screw into the back of the t-case where the speedo cable normally goes to correct the error. I used to run one on my '85 when I had 33s and 5.29 gears. Or swap out the differentials with a set of 4.56 gears and the speedo will be correct and the truck will have more pep as well.
Old May 19, 2009 | 10:50 AM
smithoman's Avatar
Wow, that's good to know. I always just dealt with how much the speedo was off.
I need to replace my speedo cable on my 90 4runner. It is a heinous operation or simple? Seems like it should be pretty straight forward.
Old May 19, 2009 | 03:58 PM
anthony1's Avatar
Try Marlin.
Old May 19, 2009 | 06:30 PM
Idk how many teeth I have.Im not gonna even attempt to check until I find some gears for it.I would hate to some how mess it up
I would change diff but Im not looking to buy a diff yet.Im saving for sas im real close to it all happening to so diff will be in that but they will be 5:71s.
I checked marlin and didnt see any
Old May 20, 2009 | 11:56 AM
anthony1's Avatar
I mean call him. He's got stuff that's not on the website.
I did my SAS with Marlin shock hoops, wheel spacers, and some stuff that's not on the site at the time.
I even have his short throw kit for my 5 spd.
Dieselmann
Feb 19, 2019 02:57 AM
okamikai
Apr 30, 2018 10:19 PM
altydog
Jul 28, 2015 10:20 AM
CanRunner
Jul 20, 2015 01:29 PM
shar
Jul 9, 2015 12:38 PM
