weird ticking noise
Old May 19, 2009 | 12:20 AM
Ebell's Avatar
weird ticking noise
hi all
Just bought a 86 pickup ext cab 22re for about 800, 200,000 miles. runs fine just got a question tho... as i accelerate i hear a ticking noise like almost a exhaust leak. Bout 10 or 15 min later the sound is barley noticeable. could this possibly mean a valve adjusting? I just cant seem to figure it out Thanks everybody...ill post pics later too
Old May 19, 2009 | 12:53 AM
toyota4x4907's Avatar
adjust the valves. While you're in there, take a look at the timing chain and make sure the guides are intact. The injectors can also have a kind of loud tick. Try to determine where about its coming from, i.e., top of engine, bottom, driver's or passenger's side.
Old May 19, 2009 | 11:25 AM
abecedarian's Avatar
Could be a valve slightly loose or could be exhaust leak near a port on the head and as the manifold heats up it expands reducing the leak.
Old May 19, 2009 | 12:13 PM
yodathespian87's Avatar
Could be low on oil... (seeing as you just bought it may wanna check, just in case) If it is a high pitch tick, I would say check the valves like everyone else has said. If its a deeper tick It could be a thrown rod. I had a tick high pitch (sounded like a valve) when I tore the engine apart found out it was a thrown rod, Causing the cylinder to not move making it sound like there was a valve problem.
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
