89 toyota pickup speedometer broke in 2 pieces
Old Jun 18, 2014 | 07:41 PM
yotatoy86's Avatar
hello all, i recently was given an 1989 toyota pickup 2wd base model (no a/c, no power steering) my question is the speedometer needle itself is broke, i can see the broken off piece inside the "glass" laying there, is it possible to purchase a new gauge cluster, but only swap out the needles? i believe it has the speedometer cable, if that helps at all. Another speedometer issue that im having is after i shift into to 2nd gear it sounds like a whining noise coming from the dash, now from what ive read online the speedo might need lubrication and/or cable be replaced, but what is the kind of lube to use? is it something i can buy at autozone? or am i going to have to go through a toyota dealer?
thanks for the help!
Old Jun 19, 2014 | 12:28 AM
Terrys87's Avatar
I have seen a thread on here about lubing up the speedometer cable. I have taken another guage and with a good needle in the past and move it over. Take two screwdrivers and gently lift at the center of the shaft to remove it. They are brittle!!!
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
paxanders
Jun 21, 2015 06:29 AM
infinityisfive
Jun 16, 2015 06:51 PM
