No power to fuel pump fuse keeps blowing
Old 06-20-2014, 07:32 PM
mattg1982@yahoo.com's Avatar
okay so i rebuilt the motor put everything back together i.e. new fuel pump/bracket installed but still not fuel to the engine and fuel pump is not responding. What i did discover is a blown EFI fuse which would blow every time i would put a new one in. As soon as i turned the key it would blow the fuse. Now i read online somewhere that my relay could b bad but i don't understand why all of this stuff worked fine before i put the block in. I also tried manually opening the mass air flow gate but still no response from the fuel pump. I suck bad at all things electrical. So any help would be great thanks.
Old 06-20-2014, 07:50 PM
btw this is on a 1993 pickup 2.4 dlx 4wd 22re
Old 06-21-2014, 09:42 AM
rworegon's Avatar
Check that you don't have a pinched or bare wire someplace in the engine bay or anywhere you were working during the rebuild.
Old 06-21-2014, 11:43 AM
jbtvt's Avatar
Yep, sounds like a short. Check for pinched wires as above, or check plug connectors for continuity where there shouldn't be any, with an ohmmeter.
Old 06-21-2014, 01:00 PM
ZUK
ZUK's Avatar
Make sure the oxygen sensor wires are not draped over the cat and shorting out.
Old 06-21-2014, 06:17 PM
holy crap this sux!!!! its a short for sure been trying to track it down all day. my relays are all good but I'm almost positive it is the white red stripe wire that sends power to the injectors and comes from the efi relay.Problem is that wire goes everywhere. Gonna pull the efi manifold in the morning and look around I've basically checked everywhere else. It has to be somtn not right in that wire around the fuel rail since that area of wires was moved around the most during rebuilding. I was very careful about avoiding this problem but i guess not careful enough.
smthwsn357
12-04-2023 02:08 AM
Charecter1
11-06-2023 10:08 AM
TURBOrunnerNM
07-22-2015 11:01 AM
redneck17
07-17-2015 07:44 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: No power to fuel pump fuse keeps blowing
