I need help with front leaf hanger.
Old Jul 2, 2014 | 06:52 PM
Do.u.even.weld.BRO?'s Avatar
Why do you have to hang leafs 1" forward and 2"down? Im going to build one but id like to get a better understanding first. 1st gen 4runner sas in progress.
Old Jul 2, 2014 | 07:15 PM
james92toy's Avatar
I think it's because the allpro and trail gear springs are longer than stock . Also if you run bigger tires they will hit the fenders so you want to move the axle forward . The 2 inches down is for spring and steering arm clearance . When the front springs flex flat they come very close to the steering box pitman arm shaft . Also might help with castor angle. You could run less hanger drop and 1 or 2 inch taller spring . Just put bump stops so nothing hits .
88sasturbotoy
Jan 30, 2026 01:57 PM
PNWrider
Oct 30, 2015 08:14 AM
shisha1999
Sep 21, 2015 08:22 PM
Backcountry411
Jul 24, 2015 08:06 AM
Nickdigg
Jul 7, 2015 06:04 AM
