93 p/u loss of power at low rpms
Old Jul 14, 2012 | 05:15 AM
DogGrass's Avatar
I have a 93 pickup 22re 4x4 5 speed. Starting this morning when i turned the truck on i noticed the engine sounds a little off. Kinda like one cylinder isn't firing. When im driving it is very sluggish until its in very high rpms. any help would be cool thanks.
Old Jul 14, 2012 | 09:01 AM
ksti's Avatar
Some history would help, what services have been done (or not).
Old Jul 14, 2012 | 09:22 AM
DogGrass's Avatar
I can't really say, just got the truck a few weeks ago. It has about 180k on it.
Old Jul 14, 2012 | 11:41 AM
ksti's Avatar
First I would down load the FSM
http://www.ncttora.com/fsm/
Then I would start by checking for vacuum leaks, and check spark plugs, maybe a tune-up you got to start somewhere.
Old Jul 14, 2012 | 11:44 AM
DogGrass's Avatar
Ok thanks a lot. I just changed out the spark plugs and wires but it's still bogging and sputtering. What are some key places to check for vacuum leaks? Thanks, Mike
Old Jul 14, 2012 | 12:44 PM
ksti's Avatar
Mike, there are no key places. Check all the vacuum lines. What brand spark plugs and wires did you use?. Are the plugs properly gaped?
Old Jul 15, 2012 | 06:47 AM
DogGrass's Avatar
Plugs are NGK and properly gaped. Wires are Napa brand. After going through the FSM i think its either the o2 sensor or the MAF. I went out this morning and checked all my vacuum lines, i didnt see anything out of the ordinary. When i started her up she ran perfect for a few minutes then started bogging down again once i started driving. Any ideas on which part i should go with first? o2 or maf? thanks
Old Jul 15, 2012 | 09:50 AM
DogGrass's Avatar
Tested the o2 sensor and it read 9.5 ohms when the fsm says 5.1-6.3 ohms. Could that be my issue?
Old Jul 15, 2012 | 11:36 AM
DogGrass's Avatar
Just went to Napa and put in an oem re manufactured MAS. The truck sputtered and stalled, plus the check engine light came on. So i put the old one back in and its drivable but still very sluggish at low rpms.
Old Jul 15, 2012 | 11:47 AM
ksti's Avatar
This is just a guess but possible cold temp sensor is bad causing it to dump more fuel thus causing bogg, but not sure maybe someone else here can assist also. Bad o2 can also cause real bad gas mileage. Don't want to see you throw a bunch of parts at it if not needed.
Old Jul 15, 2012 | 12:31 PM
DogGrass's Avatar
Yeah I appreciate it. I think I'll check out the cold temp sensor next. I remember now that the thermostat was acting funny the day it happened.
Old Jul 15, 2012 | 12:48 PM
DogGrass's Avatar
I looked through the FSM and didnt see anything about a cold temp sensor. Is it just the regular thermostat or something else?
Old Jul 15, 2012 | 12:57 PM
ksti's Avatar
Look under MFI section just above cooling section cold start injector and cold injector time switch.
Old Jul 16, 2012 | 01:40 PM
DogGrass's Avatar
The problem has gotten considerably worse today, truck wont even run for more than 2 seconds now. Taking it to the shop next week, ill post what the issue is once they find it. Thanks for the help though ksti.
Old Jul 16, 2012 | 05:57 PM
ksti's Avatar
Sorry, I wasn't much help it looks like, but yea let me know what they find.
Sleaker
Aug 26, 2020 06:03 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
kyletbert
Jul 17, 2015 11:39 AM
cars-guy
Jul 11, 2015 07:51 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
