engine feels like it's missing some horsepower
Old Sep 5, 2009 | 05:17 PM
buckz6319's Avatar
Old Sep 5, 2009 | 05:20 PM
yoterr's Avatar
i would try to add a ground, i had kinda the same prob when i swapped a 20R into an 86 when i didint have enough grounds the lights dimmed and the voltmeter would jump around and would move with the blinker n such n the more stuff i turned on the crappier the motor ran, all i did was add the stock harness from the truck back on (goes from the fender to the bat, and down the the motor) maybe you can add another to the frame or somethin?
Old Sep 5, 2009 | 05:51 PM
buckz6319's Avatar
Old Sep 5, 2009 | 06:49 PM
abecedarian's Avatar
so valve clearances have been checked and shimmed to bring in to spec?
(yeah, I know you hate me. )
thermostat is the factory rated temp and the AAV under the throttle body has no issues (clogged coolant or air passages)?
noise from the AFM? hmmm.... you've checked the entire intake for cracks from the throttle body to the air filter, and every thing else? by "pushing on the measuring plate" do you mean that if you put your finger in and open the AFM a little bit, things sound better and smooth out?
Old Sep 6, 2009 | 06:02 AM
buckz6319's Avatar
Old Sep 6, 2009 | 06:29 AM
nv4runner's Avatar
When was the last time your fuel filter was changed? I'd also check that one of your new spark plug wires isn't bad. Manufacturer defects do happen and would cause very poor performance. My engine performance books specify 10K ohms per foot for a good plug wire. The 95 4runner FSM says Max of 25K ohms per cord. Anything above that and you are losing voltage necessary to get that spark to jump the gap. Good Luck.
Old Sep 6, 2009 | 07:11 AM
buckz6319's Avatar
Old Sep 6, 2009 | 08:02 AM
yoterr's Avatar
yeah i would def check valve clearances like abe said, when i reinstalled my head i had a dead cylinder and it just ran like poo, all of my valves were out of spec but one was bad enough that it was holding the intake valve open slightly....no good, good luck!
Old Sep 6, 2009 | 10:03 AM
buckz6319's Avatar
Old Sep 6, 2009 | 01:04 PM
buckz6319's Avatar
Old Sep 6, 2009 | 02:59 PM
yoterr's Avatar
that sucks, the only other thing i can think of is puttin some sea foam in her and see if that frees anything up.....you dont have to put it in the oil just half in the tank and the other half down the brake booster line....maybe if your injectors arent spraying in an even pattern or something...
Old Sep 6, 2009 | 04:18 PM
buckz6319's Avatar
Old Sep 6, 2009 | 04:30 PM
yoterr's Avatar
?!?!??!dude ur timing light seems fed up?? its suppose to keep flashing on and off rapidly or maybe ur #1 plug is only firing intermittently?? somthins def not right there.....
Old Sep 6, 2009 | 04:37 PM
yoterr's Avatar
or maybe im an idiot.....lol i just looked at other vids and they seem to be doing the same thing....ive only used the elcheapo timing light so mah bad
buckz6319's Avatar
Old Sep 6, 2009 | 04:44 PM
yoterr's Avatar
well its toss or turn, some of em do it and others dont, ive only seen a cheap strobe timing light that just strobes every time the plug fires, but based on that it seems its not fireing correctly
Old Sep 7, 2009 | 03:05 PM
buckz6319's Avatar
Old Sep 7, 2009 | 03:34 PM
mac9968's Avatar
Good trouble shooting Buckz, very interesting results. I see the only consistant fire coming from 5, I will watch again.
Old Sep 7, 2009 | 03:38 PM
mac9968's Avatar
Looking again, perhaps 5 and 6 are doing the job. As I remember code 14 from an earlier post, are you still getting it periodically. I am wondering if that is not also telling you that you are getting inconsistant fire. Did the igniter get replaced?
Old Sep 7, 2009 | 04:13 PM
buckz6319's Avatar
