engine feels like it's missing some horsepower
Old Sep 9, 2009 | 06:14 PM
  #41
thook's Avatar
And, here it is.........
https://www.yotatech.com/forums/f116...cation-154218/
BTW, I found every auction going for an airflow meter. But, the problem is none were really tested. One dude figures checking the vehicles diagnostic system for codes was adequate, but the problem is a bad VAFM will not always throw a code. So, it has to be checked with an ohm meter. The others, well I've not heard back from one seller on my request to test it, yet. He's got a reasonable price, but if he won't test it I won't buy it. Actually, that's the seller/auction you posted the link on. Another is brand new with a lifetime warranty. It's really moot on both counts, though. I found one from DeathCougar at Nix99 for a great price I think I'm going to go with.
Thanks for the info and the tip, Dwayne. Looks like I won't have to spend alot to solve my issue.
Old Sep 10, 2009 | 02:34 AM
  #42
buckz6319's Avatar
Old Sep 10, 2009 | 04:12 AM
  #43
vital22re's Avatar
totally a bro
if i were you i would pull your injectors out, send them out to an injector shop to have them cleaned and flow tested. while they are out. pull out the plastic cups the injectors sit in on the lower plenum and replace the o-rings and maybe run a little silicone around them to make sure you're not getting an airleak there. check you're oil as well. Chances are if you're running around with this miss you're getting unburned fuel mixing with the oil which can be devastating to your motor.
Old Sep 10, 2009 | 04:30 AM
  #44
jrohland's Avatar
Swap injectors
Originally Posted by buckz6319
...I don't know it it really matters now, I checked the injector ohms on that #6 this morning (Cold) and the reading was 14.2 so I guess it wouldn't be the injector because it is within specs of 13.4-14.2
That only tells you the actuator coil is not open or shorted. The injector could be sticking open or have other mechanical problems. Why don't you swap it with one of your other cylinders and see if the discolored spark plug problem follows the injector.
Also, you may want to swap plugs between #6 and some other location NOT the one you swapped the injector into. This way you can see if plug #6 gets darker again even with a different injector.
jrohland
Old Sep 10, 2009 | 08:00 AM
  #45
buckz6319's Avatar
Old Sep 10, 2009 | 09:22 AM
  #46
thook's Avatar
Intall your jumper into the TE1 and E1 terminals, turn the key over to IG, and see if the CEL comes on and flashes consistantly.
Old Sep 10, 2009 | 10:52 AM
  #47
CrazyEye's Avatar
may sound stupid but I was having a similar problem with a nissan pickup. I tried everything dumped all kinds of money into trying to fix it. So I had my Dad look at it and he dug under the hood wiggled a few connectors around till he came on one that made the motor sound better. turned the truck off took some electrical cleaner to it and sanded the contacts and bam all was good from there. Just my input sometimes is the small things we over look. Good Luck.
Old Sep 10, 2009 | 11:56 AM
  #48
buckz6319's Avatar
Old Sep 10, 2009 | 04:47 PM
  #49
buckz6319's Avatar
Old Sep 10, 2009 | 04:54 PM
  #50
buckz6319's Avatar
Old Sep 10, 2009 | 05:35 PM
  #51
yoterr's Avatar
thats weird....isnt their a miss fire CEL? for cyl 123456? soooooo it should throw one as soon as you unplug a sparkplug wire...?hermm
Old Sep 10, 2009 | 05:42 PM
  #52
buckz6319's Avatar
Old Sep 10, 2009 | 05:52 PM
  #53
yoterr's Avatar
lmao good luck
Old Sep 10, 2009 | 06:58 PM
  #54
abecedarian's Avatar
On these trucks, being pre-OBDII, you won't get a CEL when a cylinder misfires unless the misfire also causes some other code like a rich fuel mixture or similar. The only thing remotely resembliing a misfire code on our trucks is a "14-No IGF for 6 or more events" and that means 6 cylinders misfiring in a row in order to throw that code and then you have something really serious going on. OBDII can tell which cylinder is misfiring but ours can't.
Old Sep 10, 2009 | 11:14 PM
  #55
thook's Avatar
thook....the C.E.L. flashes like it should with the terminals jumpered no problem...I've done it at least 50 times in the last year and just last weekend...
Okay, okay........just wanted to make sure the diagnostic system was working. Apparently it is....
Old Sep 10, 2009 | 11:17 PM
  #56
thook's Avatar
Bingo.
Old Sep 10, 2009 | 11:28 PM
  #57
thook's Avatar
ok here is another update.....I'm still troubleshooting the issue with why I don't get a C.E.L. with some electronics unplugged, and I do get a C.E.L. on with others unplugged.....I think I should get a C.E.L. on with all the items I list below (not just some) ...man is this getting confusing
Unhooked the harness connector from these one at a time with engine running
1) T.P.S.(rpms rise,I think it should do that?)
2) coil primary(kills engine as it should)...throws a C.E.L. when restarted
3) coil pick up coils(kills engine as it should)
C.E.L. on dash comes on
I unhook the harness connector from these one at a time with engine running
1) fuel injector on #2,4,6 (can't get to #1,3,5 unless I remove the plenum so I'll check them later)... No C.E.L.[/COLOR]
2) plug wire from spark plugs #2,4,6 ...No C.E.L.
3) Dizzy coil pick up connector (this kills the engine as it should)....throws a C.E.L when restarted which should be correct
any help will be appreciated
Dwayne, listen man.........the things you are unplugging and not getting a code for do not have a code. It's not programmed into the diagnostic system. What reference are you using for deciphering engine codes, by chance?
No matter......
I learned yesterday that a coil can test good for all practical purposes on an ohm meter (according to the FSM) and yet still be bad. A pro mechanic explained this to me after relaying a recent experience with his dragster which he put a brand new, very expensive, high performance, high quality coil on. But, when he got it to the track, the dragster hit hard off the line and then promptly fell flat on it's face. He put another spare on that he knew was good and went on to race. He also explained how he tested the coil that was a much more imperical way, but since his knowledge is over my head I didn't quite understand. I would have to drop in to his shop sometime so he can show me how it's done. Point being, head to O'Reilly and get another coil. Put it in. If it changes nothing, take it back, tell them you didn't install it, and get your money back. They really don't care.........well, as long it's not the manager.
That's what I would do, anyway. Rule it out.
Oh, and if it does make the difference, I guess you needed a new coil.
Old Sep 11, 2009 | 02:29 AM
  #58
buckz6319's Avatar
Old Sep 11, 2009 | 02:54 AM
  #59
vital22re's Avatar
totally a bro
unfortunately this system doesnt' tell you if you've got a misfire or which specific cylinder misfires. So unpluging the injectors or pulling the plug wires wont trigger a light.
Old Sep 11, 2009 | 08:05 AM
  #60
buckz6319's Avatar
