3rd member swap question
Old Sep 15, 2009 | 11:11 AM
Adh007's Avatar
My truck is a 1993, 22re, 5 speed with factory 4.10 diffs. (pickup)
I'm thinking about swapping in a pair of 3rd members taken from a 1991, V6, 4runner with 4.56 gearing.
The front 3rd member, based on my research, is identical.
The Rear, based on my research is slightly different but still interchangable.
Here's the problem:
Aussie Lockers appears to make a locker for the rear of a 93 4cyl pickup, but NOT for a 91 6cyl 4-runner..... and I want to install an aussie locker while the 3rd member is out.
Am I out of luck or will the locker for a 8" standard fit?
Old Sep 15, 2009 | 12:01 PM
Junkers88's Avatar
You my friend are out of luck. Aussie has been putting that off for years. Your best bet would be to find a 4cyl rear in the gearing of choice or get a lockrite locker.
Old Sep 15, 2009 | 12:16 PM
bain's Avatar
Is Aussie EVER going to make a locker for a V6 3rd??
Old Sep 15, 2009 | 12:33 PM
OutlawMike's Avatar
Just get the Lockright, it is damn near identical to the Aussie and the price difference is not that much.
I have the Lockright in the front and rear of my '89 V6, I love them. The one in the back talks to me all the time driving around town, keeps me company.
Adh007's Avatar
This just came into my email a couple minutes ago, I'm not sure if they're to be trusted...
Originally Posted by engineering@aussielocker.com
We have a new V6 manufactured and are waiting for Australia engineering to finish the installation manual. We hope to have an announcement within two weeks.
Old Sep 15, 2009 | 12:40 PM
BLKNBLU's Avatar
Ditto, except the talkin' part. Mine is pretty transparent.
If I had a nickel for every time...
Old Sep 15, 2009 | 12:54 PM
THEYCALLMEZP's Avatar
hows is the lockright in the front i just put 5.29's with a lockright in the rear it works really well. but it does do some talkin around town. i wanna do one in the front to. how does yours work??
Old Sep 15, 2009 | 12:59 PM
Adh007's Avatar
I suppose I could go aussie front and leave the rear open in the off chance they will one day make the V6 rear....
I just have the (probably misplaced) fear of stuff binding up and popping and not being able to turn a tight turn on the trail with the front locked up.
Old Sep 15, 2009 | 01:09 PM
olharleyman's Avatar
I have been seeing that same responce for over 2 years now and at one time around a year ago they were posting here the same thing with a bit different time line but it was the same thing
ALL TALK NO ACTION/PART
Mine does two it has a way of making the 35's bark in tight corners and parking garages
In the front your turning radius is cut in half but that's what reverse is for and if your not useing it on the road you will have no problem as long as you don't lock your hubs , with the A.D.D. system I think as long as you don't shift into 4wd it will be just like manual hubs but I have no experience with the A.D.D. set up I did manual hubs at the same time as the front locker
Old Sep 15, 2009 | 01:29 PM
OutlawMike's Avatar
As said above, it cuts down on the turning radius offroad. The traction is nothing short of incredible. I went from open/open 4.10's to locked/locked 5.29's, just marvelous offroad.
I would not want to drive it on pavement in snow in 4x4. But, I'm in coastal Cali, snow is a non-issue around here.
Best case, all around, I would want an ARB up front. But, I don't have that kind of coin right now, so, the Lockright will do for now.
In the rear, I find the Lockright talking to me on the road. Anytime I turn tight and get on the skinny pedal, it barks at me. You learn to coast though most tight turns, maybe light pedal after entering the turn once it is ratcheting. Also, it turns heads even when coasting, as it goes thunk, thunk, thunk back there, ratcheting around.
On the highway, I don't notice a thing, I just drive it.
I will believe it when I see it on the V6 Aussie, they are just not in that market.
Old Sep 16, 2009 | 01:29 PM
Thumbs down swappin thirds
so now like he asked in the beginning if i pulled the third out of the rear of my 88 runner will it go in the front of my 84 housing with no issues?
Old Sep 16, 2009 | 02:49 PM
Junkers88's Avatar
It should.
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Coreyr384
Jul 10, 2015 11:13 AM
