Quick Locker swap Question
Old Jul 1, 2012 | 07:58 PM
Jonzzer's Avatar
Im trying to swap an Aussie locker into my 88 4runner diff. I bought a whole third member with 5.29 gears. I know swapping the front over to 5.29 would be better in the long run but dont have the $$$. MY question is can i pull the locker with the ring and spider gears unit and swap my 4.10 ring gears on to it? or is that to simple... would i then have to redo the backlash?
Old Jul 1, 2012 | 08:13 PM
justin_4runner's Avatar
u can just take the 3rd out of ur runner and using the 410 gears and housing and put just the locker in replacing the open diff, u would need to check ur backlash before and after u do it and make sure u get them right, also i would paint the gears to see how its meshing just to make sure u have it all set right.
Old Jul 2, 2012 | 05:06 AM
waskillywabbit's Avatar
If not reset up right it won't matter you swapped anything.
:wabbit2:
Old Jul 2, 2012 | 05:26 AM
rattlewagon's Avatar
You also have to change the pinion...
Anytime you pull the ring gear and pinion apart, you should check the backlash..
Check this page out.
http://www.gearinstalls.com/
Old Jul 3, 2012 | 01:05 PM
Jonzzer's Avatar
Hey thanks for the links. amazed at how much time has been put into that site for others benefit. I got one question though. The backlash is the slop between the ring and pinion ... right? so ill have to measure it before and after on my 4.10 third that the aussies going into, and not worry about the 5.29 backlash? when swapping the ring gear do i need to it a specific way, or just bolt it on and torque to spec ?
Old Jul 3, 2012 | 04:21 PM
Duffdog's Avatar
the ring and pinion are machined together when they are made. You can't use a 410 pinion on a 529 ring, or even swap brands.
Normally, you check the backlash with a machinists dial indicator. I've always done it by feel and had great results. I still painted the gears and checked the pattern to prove that it was done right.
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
icentropy
Jul 14, 2015 10:23 AM
Coreyr384
Jul 10, 2015 11:13 AM
