help!! inner spindle bushing too large?
Old Mar 19, 2007 | 04:55 PM
runner126's Avatar
im replacing the spindle bushings and i installed the inner bushing and its too small it doesnt fit over the axle shaft.....is this common?. the old bushing fit well and is about .06 of an inch larger (inner diameter micrometer measurement). I tried to heat it up but it just wasnt enough. is this normal for a "tight" fit with the new bushing. does anyone have any ideas. how do i make it fit. any help is greatly appreciated.
Old Mar 19, 2007 | 05:04 PM
runner126's Avatar
anyone?
Old Mar 19, 2007 | 05:10 PM
runner126's Avatar
.......please im going to
Old Mar 19, 2007 | 06:44 PM
Brenjen's Avatar
*bump*
Just take a deep breath, someone will be along that can answer your question. I have not had mine apart yet so I can't give you accurate info. but, are you sure #1 that it's the correct part & #2 that you installed it correctly?
Old Mar 19, 2007 | 06:48 PM
ChickenLover's Avatar
Did you deform it while you were pounding it in?
Old Mar 19, 2007 | 07:03 PM
runner126's Avatar
yeah its in straight and went in fairly easy. to install i had to throw it in the freezer and it fit right in. the bushing matchs the old one in look and part number. could i just sort of hone it out with a fine grit sand paper alittle at a time.?
Old Mar 19, 2007 | 07:15 PM
runner126's Avatar
the old one is in ok shape and would it be a bad idea to put the old one back in. ? after a quick .....i feel much better
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
G-off
Dec 29, 2015 12:44 PM
Pocoyota
Sep 8, 2015 02:41 PM
