Bypass load leveler
Old Mar 20, 2007 | 07:22 AM
danimalstwiztid's Avatar
Bypass load leveler
Is there any way I can bypass the load level bar that goes from the axel housing to the frame? Can I just make a connecting line for the brake lines?
Old Mar 20, 2007 | 08:09 AM
BlackSR5's Avatar
there is a writeup on here somewhere....maybe on 4crawler.com
Old Mar 20, 2007 | 05:54 PM
SoCal4Running's Avatar
Yea; use a turn-buckle to adjust to your liking.
Old Mar 20, 2007 | 06:00 PM
DeathCougar's Avatar
The point of that thing is to keep the rears from locking up, no? Why remove it?
Old Mar 20, 2007 | 09:50 PM
OicnaiC's Avatar
Is this what you're looking for? http://www.off-road.com/toyota/cheaptricks/brakevalve/
Old Mar 21, 2007 | 02:23 PM
BRreddog's Avatar
http://www.imagestation.com/7624219/3932997331
You need one of these.
http://www.imagestation.com/7624219/3932997315
Remove the line from the rear to the front and plug the tee.
http://www.imagestation.com/7624219/3932997273
Then remove the LSPV and connect the line to the rear brake tee.
I will be adding a second manual valve in the rear as the one at the master is adjuted all the way out.
I removed mine because I added rear disks.
http://www.imagestation.com/7624219/3932997292
kawazx636
Oct 6, 2021 03:03 PM
smilen724
13
Nov 8, 2015 04:11 PM
kcaudill
Oct 10, 2015 02:39 PM
charlie_fong
Sep 27, 2015 10:06 PM
mtrdrms
Sep 26, 2015 07:12 AM
