Water Leak help!!
Old Mar 18, 2007 | 06:12 PM
captain204mike's Avatar
Water Leak help!!
Ok, i have a 93 Toyota Pickup with a 22re, i just had a Jasper engine put in, and discoverd a little leak under the truck,, got to searching and looks like it is leaking from the "thingy" that is under the oil filter,
question is what is that Thingy??
has a wire going to it, and looks round, maybe a sensor, not sure what it is called thats why im asking??????
Old Mar 18, 2007 | 06:16 PM
DeathCougar's Avatar
Either the knock sensor, or the oil pressure sender. Neither of which has coolant going to it.
btw pics are worth 1000 words.
Old Mar 18, 2007 | 06:26 PM
Well it is possible it is oil,
ive never had a new engine before where the oil is as clear as water, lol
if it is the oil pressure switch, is it possible for oil to drip out of there??
ill try to take a picture tomorrow of it and post it
Old Mar 18, 2007 | 06:33 PM
yes, its possible if the sensor is not tight.
Old Mar 18, 2007 | 06:36 PM
AuburnRunner's Avatar
do the taste test on the mystery fluid. sweet=coolant
Old Mar 18, 2007 | 07:18 PM
big_blue_goat's Avatar
watery substance from that area could possibly be condensation from an AC system. Just a thought...
Old Mar 19, 2007 | 04:21 AM
my truck doesnt have AC, wished it did, anyhow i will try to get some pics today of the unit i think is leaking
Old Mar 19, 2007 | 04:30 AM
BlackSR5's Avatar
Engine block heater? Mine is leaking like crazy right now. I think its an aftermarket part installed in a removed freeze out plug... trying to figure out how to tighten mine. Keep an eye on your coolant level!!!!
Old Mar 19, 2007 | 05:33 AM
dang i hope not,, this motor has 100 miles on it,, a jasper install
hopefully just that oil switch or whatever it is called, didnt have a wrench with me to tighten it up to see if that was it,,
and i believe it is oil, just a very small drop or 2 was under the truck this morning and looked like oil
Old Mar 19, 2007 | 05:35 AM
rdlsz24's Avatar
If it's under the oil filter and kinda to the right, it's the oil pressure sender. I say sender because you say it's round. If it were long and skinny, it would be a switch.
Rob
Old Mar 19, 2007 | 06:09 AM
yes i believe it is the oil pressure sender,
so is it possible that it is dripping out of there, and down on the front running gears and then on ground,,
sound like the right area??
Old Mar 19, 2007 | 07:20 AM
rdlsz24's Avatar
Yeah it's possible. You should just be able to take a crescent wrench and tighten it up.
Rob
WellsR
12
Jul 31, 2015 03:27 PM
TJWilly
Jul 31, 2015 02:05 PM
jjrbus
Jul 19, 2015 02:06 PM
Jonny246
Jul 12, 2015 04:51 AM
Avenged
Jul 9, 2015 07:55 AM
