After headgasket no fuel!
Old Mar 12, 2007 | 07:46 AM
jagger_snitt's Avatar
Do I need to Prime the fuel pump? Is there anything I need to do?
If carb cleaner or some flamable is shot in to the intake and the engine turn over for a sec it tries to run. Any help would be appreciate.
I miss driving it so bad.
Old Mar 12, 2007 | 07:47 AM
dcg9381's Avatar
Carb or EFI?
If EFI - make sure you put the ground wire back on the manifold.
Other than that - check fuel pump first (4crawlers page) and then that injectors are being triggered.
Old Mar 12, 2007 | 07:49 AM
rdlsz24's Avatar
What did you all take apart with the fuel system when you replaced the head gasket? Are you sure you got the injectors, fuel line to the plenum, etc put back correctly? It should fire right up.
Rob
Old Mar 12, 2007 | 08:38 AM
Sorry it is EFI. Is the ground that your talking about the one that comes from the firewall to the area of the hook that bolts on the rear of the head?
We replaced 2 injectores and the fuel filter.
Old Mar 12, 2007 | 11:10 AM
rdlsz24's Avatar
Are you sure you installed the filter correctly?
Rob
Old Mar 12, 2007 | 11:18 AM
I was pondering that myself. I believe so. I'm going to check my grounds again.
I really hope we have just missed a ground.
thanks.
Old Mar 12, 2007 | 11:26 AM
DH6twinotter's Avatar
It took me several tries for mine to fire up after I had the fuel rails and injectors removed. I had a lot of air in my lines.
Just my $.02.
Old Mar 12, 2007 | 12:13 PM
TY everyone
,hopefully this will help me narrow it down a little
Old Mar 19, 2007 | 05:42 AM
EFI fuse was blown. Had to "Jumpstart" or "Prime" the EFI system.
Fired right up.
for those that are curious.
Old Mar 19, 2007 | 08:27 AM
TNRabbit's Avatar
thanks for the update; glad you were able to get it running....
Old Mar 19, 2007 | 08:39 AM
Yeah all that is left is adjusting the Valves and timing.
I always like to try to complete posts. Nothing sucks worse than a dead end post,when your searching for answers.
wafoogalla
Nov 2, 2016 11:02 AM
defrag4
Jul 31, 2015 10:50 AM
toofly1999
Jul 25, 2015 07:09 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
