Exhaust upgrades on 22re
Old Jan 1, 2010 | 12:59 PM
toyfitter's Avatar
What are some of the exhaust upgrades that you have done on your 22re. And did it make a difference in performance? Headers, Pipe size, ....
Old Jan 1, 2010 | 01:04 PM
kiyobrown's Avatar
I am all stock with an exhaust leak at the manifold and 3 leaks in the muffler. I ordered a full exhaust kit from lce. Header, 2 1/4" cat, and 2 1/4" full exhaust. Might not have it all together for a couple weeks (backordered). But I will keep you posted.
Batt/ intake swap with a supra maf helped with throttle response and maybe 1mpg increase, which has since been erased by the exhaust leak.
Old Jan 1, 2010 | 01:08 PM
AzStorm's Avatar
LCE 2.25" header,cat & muffler and tailpipe.
Made a little difference but nothing to write home about.
It took other mods to go along with the exhaust mod to see and feel a difference.
I think the biggest improvement I noticed on my 22re has been the overbore throttle body and matched bore intake.
A motor is essentially an air pump.The more air it pumps the more power it makes.
Old Jan 1, 2010 | 01:12 PM
BigBluePile's Avatar
This has been covered at LEAST once...let me search around on here for YOU. I'll post up in a minute...
Old Jan 1, 2010 | 01:14 PM
kiyobrown's Avatar
It has? I'm not too sure about that Logan.... Although you MIGHT be trustworthy enough to believe.
Old Jan 1, 2010 | 01:20 PM
I'm still searching...I'll post links soon...
Old Jan 1, 2010 | 04:07 PM
kiyobrown's Avatar
Originally Posted by Gnarly4X
Oh my gawd@!!!
Exhaust upgrades... OK let's do it@!@!
I think that a Doug Thorely header with 2.25" exhaust, and a free flow muffler is as good as it gets. You should see about a 10% gain in HP on a healthy stock 22RE. You will probably lose just a tad of torque from off-idle to around 2,000 RPM, but you'll see a nice increase in throttle response from there up.
TJMWO,
gNARLS.
perfect, do that setup, then we can trade rigs and see if one is better then the other.
Jun 1, 2021 01:51 PM
RatOmeter
Oct 22, 2015 03:17 PM
garagespace
Oct 11, 2015 10:59 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
