Just scored an E-locker / have questions.
Old Dec 23, 2009 | 11:21 AM
JollyGreen's Avatar
It came from a 98 4runner 4x4
Axle code was A04A.
I have confirmed it is 4:30 gears but is it a 7.5"
Thats what the A is supposed to mean, but I thought all E-lockers are 8".
can anyone help me?
Old Dec 23, 2009 | 11:29 AM
tj884Rdlx's Avatar
the meaning of the letters changes somewhere, i think 96, and the A no longer means 7.5. so when you look in one of those online code lists, you have to make sure you're looking at one that applies to your source vehicle. if you have the parts in hand, i recommend measuring them.
Old Dec 23, 2009 | 11:35 AM
TOYOTA 1's Avatar
the codes are on the door jam right?
did you mistakenly look at the code for the front?
Old Dec 23, 2009 | 11:47 AM
87AzRunner's Avatar
pretty sure elocks were in the rear only, correct me if im wrong, but yes it will be an 8 in then as long as it is out of the rear, 7.5 front 8 rear
Old Dec 23, 2009 | 11:55 AM
JollyGreen's Avatar
Yes, rear Elocker.
Old Dec 23, 2009 | 06:16 PM
91diesel's Avatar
those axle codes mean nothing on taco's and 96+ toyotas. I've tried to find a decoder for the later model axle codes but there is no such thing, even the dealers couldn't decode the axle codes on them
Old Dec 23, 2009 | 06:38 PM
flyingbrass's Avatar
Will any year of e-locker (complete third?) work in 86-95's as long as it's an 8" with the desired gearing?
What should I be looking for to use in my 86?
Old Dec 23, 2009 | 06:55 PM
JonnyBoy's Avatar
Up to '03 I'm pretty sure. Don't know about after that, though. I believe mine is from a '98, but then again I'm going off what the ebay seller said, so...
Any 8" Elocker should work, even the high pinion Elocker from the front of Land Cruisers
Old Dec 23, 2009 | 07:08 PM
bend's Avatar
how much is a decent price to pay for an elocker?
Old Dec 23, 2009 | 07:16 PM
JollyGreen's Avatar
$4-$600 depending on condition, miles, recent rebuild etc...
Old Dec 23, 2009 | 09:51 PM
rhill's Avatar
pretty sure quite a bit of fabrication is required to make this work:
http://www.4x4wire.com/toyota/tech/electric_locker/
http://pirate4x4.com/forum/showthread.php?t=806250
what kind of truck are you putting this into?
be sure to post your progress, i'd love to do this myself, just not sure if it'll work!
Old Dec 24, 2009 | 03:46 AM
JollyGreen's Avatar
94 pickup 4wd 5spd
Old Dec 24, 2009 | 04:23 AM
shaeff's Avatar
It's a common swap, and well documented. From memory:
You'll need one or two longer studs, drill a hole or two in your housing, and an e-locker gasket (and some RTV). Assuming it's the same gear ratio as your rig, it's not difficult to swap in.
Old Dec 24, 2009 | 06:14 AM
91diesel's Avatar
shaeff is right, it's not hard I did it to my 91. Also all the taco/4runner/fj cruiser e-lockers are the same up through 09 (gearing not withstanding). I've got an 07 or 08 e-locker under mine right now from a taco to get the 3.73 gearing. All the 05+ V6 taco lockers are 3.73, I believe the 4cyl ones are still 4.10 or 4.56.
Old Dec 24, 2009 | 06:41 AM
dropzone's Avatar
Fossilized
why did you want the 3.73 gearing? I hated it in my '05 Taco TRD. way too high...
get an elocker skid..the actuator is an expensive replacement by itself
Old Dec 24, 2009 | 06:55 AM
91diesel's Avatar
it's cause of how torquey my 3.0 is. I just didn't need all of those rpms on the highway with 255/85/16's.
Old Dec 24, 2009 | 07:25 AM
93yotaSR5's Avatar
could you just swap out the whole rear from a taco into a pickup?
Old Dec 24, 2009 | 08:00 AM
shaeff's Avatar
I haven't looked into a Taco rear in a while, but you'd probably have to change spring perches and whatnot, aside from the fact that I think it's a bit wider than our stock axles.
Old Dec 24, 2009 | 09:47 AM
MaK92-4RnR's Avatar
I believe the swap is completely inner changeable. You can also swap a tacoma bed as well. but someone correct me if i'm wrong.
Old Dec 24, 2009 | 09:56 AM
89silverpu's Avatar
You cannot swap the whole axle assembly. Spring perches do not line up etc...
Click on the link in my sig for my e locker retro fit.
