TPS Measurment Help
Old Dec 28, 2009 | 08:30 PM
clk_cpa's Avatar
TPS Measurment Help
My TPS is measuring Open/Infinite between E2 and IDL at anything above 0.2mm on the feeler gauge. I'm also reading 15K at 0.117mm. Accordign to the 4crawler site, I should read under 2.3K with 0.5mm feeler gauge. All the other tests are checking out OK. Do you think the TPS is bad or it needs adjustment? I want to be sure before i start messing with it or replacing it. THA
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Jan 4, 2010 | 04:43 PM
Tye7's Avatar
Truck: 22-RE
I have a similar issue. I have a truck thats stuck at a 2k idle speed that varies slightly. The E1 TE1 jumper does nothing to the idle speed.
I tested the TPS today. VTA and E2 check out fine, perfect stats throughout the range, but the IDL E2 gets nothing.. no readings at any range in the throttle. Bad TPS?
Old Jan 4, 2010 | 08:08 PM
abecedarian's Avatar
4Crawler has rather specific measurements for testing the TPS. Follow them. If he says use an 0.5 MM gauge, use it.
Originally Posted by Tye7
Truck: 22-RE
Likely a TPS that needs adjustment. Follow the guide on 4Crawler's site, linked above.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
voiddweller
Oct 2, 2015 07:47 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
