1986 4runner running to cold?
Old Dec 30, 2009 | 07:46 PM
99 sas runner's Avatar
my guage bearly moves off of the cold line all the time. its freezing out side and my heater sucks beacuse my coolant wont warm up. i put a new 180 t-stat in and still nothin. any ideas??
Old Dec 30, 2009 | 07:55 PM
myyota's Avatar
The stock thermostat should be in the 195 degree range, also check the temperature gauge sending unit, they can go bad and not read properly, i had it happen to me. For the heater, make sure the heater control valve under the hood is working, when they get old they can freeze up and not open. I had this happen on my 86 4Runner and i replaced the heater valve with one from a 90 4Runner, its plastic so it won`t rust or freeze up. You might also back flush the heater core to clean it out.
Old Dec 30, 2009 | 08:07 PM
when i rev it high or while driving i can hear coolant flowing through the heater core
Old Dec 30, 2009 | 08:09 PM
and ill replace the temp sensor to be sure but im prety sure the heater controll is working fine
Old Dec 30, 2009 | 08:13 PM
ScottyC's Avatar
Sounds like you have an air bubble or its not full. 22RE's typically run on the cold side in the snow belt. Try running a piece of cardboard in front of the radiator to see if it helps.
Old Dec 30, 2009 | 08:40 PM
cool thanks my radiator leaks so i need to replace it first the wierd thing is that my buddys 85 runs a little below half in the same weather so idk
Team420
Jan 12, 2021 04:57 PM
Cesarl74
Apr 23, 2016 06:07 PM
vasinvictor
Jan 20, 2016 12:39 PM
jmc88runner
Jun 18, 2015 03:39 PM
