Help with 4 runner please/power steering
Old Dec 30, 2009 | 03:17 PM
missionsix's Avatar
I'm looking into buying a nice 4runner from a friend. He says that when the power steering is hooked up, it burns up and out the exhaust. So, what could cause the power steering fluid to end up in the exhaust system? Is this a serious problem? Do I need to include any more info on the vehicle? Thanks for the help.........
Old Dec 30, 2009 | 03:27 PM
bipolarandproud's Avatar
It's not possible./ it most likely oil coming out OR coolant . The power steering runs off a pully . It sounds like there are problems with the 4runner ,
-That's my opinion .
Old Dec 30, 2009 | 04:10 PM
iamsuperbleeder's Avatar
bingo, yota4runna
not the first time I've seen it happen
Old Dec 30, 2009 | 04:11 PM
missionsix's Avatar
Originally Posted by yota4runna
Would it have been too much trouble to include more info on the vehicle?
Here's what the problem would be if you had first generation 4Runner. On the top of the power steering pump is a valve with vacuum hoses connected. This valve allows a little air to bypass the throttle body when it senses an increase in the power steering pressure when you turn the steering wheel. Turning the wheel adds a load to the engine, and this valve keeps the load from stalling the engine. When the valve develops an internal leak, the engine vacuum will suck the P/S fluid from the system. This should be a cheap and easy fix if you have a wrecking yard nearby.
Ah man, you rock!!!!! This confirms my internet research. Thank you very much. Sorry about the limited info. I've kinda just decided, on a whim, to buy this truck. So, I'm limited on the details. It's a '93 with 147,000 miles very clean.........for 2,600 bucks. I think I can take it for 2,000.
Old Dec 30, 2009 | 04:13 PM
holy crap! yeah that's a pretty good deal, considering I paid $3000 for my bone stock 91 with 270k miles on it
how 'bout some pics
Old Dec 30, 2009 | 04:17 PM
missionsix's Avatar
how 'bout some pics
I have nothing 'til the morning. I live in the sticks and the weather sucks right now.
SIDE NOTE: This looks like a parking lot fix?
Old Dec 30, 2009 | 04:20 PM
missionsix's Avatar
Shucks! I never mentioned it was a '92 v-6 and I think it's an auto trans....... Sorry again. Thanks for the help.
Old Dec 30, 2009 | 04:21 PM
haha, alrighty
and oh yeah, shouldn't take but MAYBE a minute to pull a valve off a junkyard motor, and maybe a minute and a half to pull the bad one off your engine, and put the replacement on
just be ready to loose a little bit of PS fluid, as a little bit will come out of the hole when you remove the valve. all it takes for the swap is a wrench and I'm willing to bet it's the same valve on the 3.0's and the 22re's
and just FYI, the PS fluid is ATF, as in automatic trans fluid. don't make the same mistake I did and use actual PS fluid that made my gearbox leak like a sieve
Old Dec 30, 2009 | 04:26 PM
missionsix's Avatar
Actually learned that from the wife randomly enough........
Sounds like I'm buying out the loan and 2,600 is what it is. I think I'm going to buy this for my wife.
Old Dec 30, 2009 | 04:29 PM
rube's Avatar
can someone post pics were those 2 hoses connect to on a v6?
Just rebuilt my motor and its the only thing im not sure if its right.
-thanks
MMA_Alex
25
Apr 18, 2017 05:07 AM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
