Hella 500FF going on new AOR bumper on 3rd gen PU
Hey guys, just bought a set of 500FF's to go on my new bumber I'll be ordering this week from Adicted Off Road (assuming you guys aren't taking an extended Christmas vacation Scotty! ), and I'm curious to how your guys are mounting some lights up to tube style bumpers other than welding tabs to the bumper. I don't have a welder, and I'd rather have something that's just an add-on and maybe removable; some sort of clamp-on mouting tab or something... but I have yet to see anything along the lines of that...
Also, any of you 500 or 500FF owners out there have any issues with moister getting behind the lense assembly? I removed the fastening screw and took a look back there, and I don't see any sort of gasket, rubber ring, or foam or aything just curious.
And you better bet that pics will be posted once this bumper is on this truck hell, might even throw in a few in-progress pics, cause you know how SuperBleeder rolls
I have the 700ffs, every now and then ill see moisture behind them but its nothing too bad. It goes away when i turn on the lights tho. I dont really like how its all held together with 1 screw that goes in to plastic.
I added a 2nd relay and then added 100w bulbs, really bright, you should do the same.
If you retrofit a set of Infinity FX35 bi-xenon projectors, you will be flat out amazed at the quality of light output, intensity, and all the while not blinding people. Trust me. OEM retrofit or FXR is far superior than most halogen setups, all the while causing less stress on your electrical system.
Are you talking to me? I've done the FX35 retrofit on my e36 M3. It's incredible. Fitting the FX's into H4 housings is a tight fit, but can be done with ease. I have a second set of the FX's sitting here which will be going into the Pickup.
Edit:
From another forum I frequent- FX35 bixenon projectors fitted into h4 housings on a MKIII Supra, which has LESS room to mount things than these trucks do due to the pop-up headlight design:
http://www.supramania.com/forums/sho...4&postcount=21
And a few images I snapped of my own FX35's while experimenting with the M3:
The housing I retro'd them into:
The cutoff. First pic from 150 feet, second and third from 25ft, fourth from 20, and that's a SINGLE projector.
The actual projector, modified to fit in the BMW housing. Must less modification would be required to fit an H4 housing because there's much more room to work with.
Edit:
no pics of what, the Hella's?
lol, ummmm, well they look like this
and they even come with a snazzy little cover
Just having fun surfing the web and enjoying my hydrocodone this afternoon getting over being sick.
I'd just do some weld on tabs (get Scotty to do it) cause anything else won't work as well IMO.
Just interesting you got a build thread about a bumper you don't have yet (i.e., ready, fire, aim as opposed to ready, aim, fire)
oh, got cha, lmao
hmmm, yeah that's not too bad of an idea... I may just ask them about that when I call them up
I'll have to get some measurements so I can tell him where I want the light tabs placed
Thanks!
Thanks!
The FX35's are bi-xenon. They use a shield that would be powered by your high beam wire/ground that's connected to a solenoid that's part of the projector housing. When you flick on your highs, the bulb stays ignited, but the solenoid for the shield is powered, pulling it down, thus allowing light to hit the bottom of the bowl (which is reflected up = high beams)
That's why I suggested the FX's- they're fantastic, durable, easy design, easy to understand, pretty cheap ( http://store.theretrofitsource.com/ for replicas that are damn near as good as the OEM's, and easier to mount!)
You don't lose ANY functionality with these, which makes them an excellent candidate. I'll post pictures when I to the truck retro, but I've got lots of other stuff on my plate before I get into that. /threadjack
X2 on converting to HID when you decide you want more light. You can get a good quality 35W HID kit for about $40.
https://www.yotatech.com/51250545-post30.html
Link: My Hella 700FF HID Conversion Thread
Link: Tacoma Territory Hella 500 HID Conversion Thread
