My timing does not advance!
Old Dec 20, 2009 | 01:16 PM
zach@sparkplugs.com's Avatar
Alright so I got a '86 22RE that's all truggified out, stripped down wiring harness, etc.
This is driving me nuts, my timing WILL NOT advance, in fact it retards. Down at the lower RPMs, it kinda jumps around, but give it some throttle and higher RPMs, and it retards like 10 degrees and stays steady there! What could possibly be causing this?
My knock sensor isn't even hooked up, and my T and E1 jumpers are not connected. I've also checked my TPS, which is in spec. Funny thing about that though, if I disconnect it while running it doesn't seem to make a difference, but like I said everything is in spec, and I checked all the wiring. Guess that's sorta normal?
Old Dec 20, 2009 | 02:59 PM
whokrz's Avatar
I would hook up your knock sensor and any other efi stuff that is not plugged in and see if it helps. If the ecu doesn't get the information it wants it defaults to open loop in order to keep the engine running.
Old Dec 20, 2009 | 03:33 PM
myyota's Avatar
Hook up the 02 sensor and the knock sensor, if there not already, that could be causing your problems.
Old Dec 20, 2009 | 10:45 PM
Thanks for the suggestions, I did those and no difference.
But I did get it figured out. Turns out my igniter was shot. Purrs like a kitten now
jbv808
Aug 6, 2021 04:47 PM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
karbin
Jul 5, 2015 11:37 PM
