My power outlet plug in
Old Dec 24, 2009 | 10:43 AM
Countryhick's Avatar
DOESnt work. it hasnt worked for a year. it worked awhile back last winter it shorted out one day. but all my fuses are good. i cant understand it. its hooked up right my fuses are okay. anybody got any ideas??
Old Dec 24, 2009 | 11:14 AM
thedanned's Avatar
Trace power and ground from the outlet to their respective sources. No easy way, just follow those wires!
Old Dec 24, 2009 | 11:27 AM
DupermanDave's Avatar
x2 x2
Old Dec 24, 2009 | 11:34 AM
Originally Posted by DupermanDave
x2 x2
haha YEah i will need a couple hours to do that.. i need that thing working though. one day i turned on a hand heater that hooked up to it and it just turned off on me and all the fuses are good so ill trace the wires.
Old Dec 24, 2009 | 01:55 PM
ilostmypants's Avatar
trouble shoot, start at the fuse panel and if you have power there there is an issue between the panel and the outlet. check the plug itself, and the connections when i got my truck the power outlet didn't work and it ended up being that the guy before me had the dash apart and didn't put the wires back on there tabs.
also i am not sure on trucks and 4 runners but on my girlfriends 2000 corolla and the power outlet radio and clock where all on the same fuse.
or just wire up a new one.
Old Dec 24, 2009 | 02:01 PM
abecedarian's Avatar
don't use AC devices on a DC plug?
Old Dec 24, 2009 | 02:15 PM
stockwell45's Avatar
same thing happened to me. i just gave up and wired a new one. wired it straight to the battery and make it a full time outlet comes in very handy
Old Dec 24, 2009 | 02:16 PM
you know what. thats a great idea i will need that haha.
Did you just run a power wire straight to it and a ground wire or what??
Old Dec 24, 2009 | 02:26 PM
Matt90V6SR5's Avatar
Thats what I need,direct power plug.Mine doesnt work either and the fuse is good.
Old Dec 24, 2009 | 02:30 PM
hah he gave me a idea. im going to put a fuse wire inbetween it so i dont burn out the item im using. lol but straight to the battery?? sound okay??
Old Dec 24, 2009 | 02:32 PM
Elton's Avatar
use at min 14ga wire and a 15amp fuse
Old Dec 24, 2009 | 02:34 PM
yeah i would just rewire the back of the outlet and just move it throught my firewall to the battery and bam??
should i use a ground of anything or the fure make it okay??
Old Dec 24, 2009 | 02:41 PM
Elton's Avatar
ya there should be a firewall plug on the pass side somewhere as for the ground could find a spot on the radio frame use a ring terminal and self tapping screw
Old Dec 24, 2009 | 02:44 PM
or icould just use the stock ground lol ill pull my dash out and just do it. since its xmas and all lol i have wire and fuse plugs and all.
I GOT A 8000K WINCH FOR XMAS. but im not supposed to know haha.
Old Dec 24, 2009 | 02:47 PM
for the ground wire you can take off the side of the center console and any of those large 12mm bolts that go into the frame should work great for the ground wire. that way you dont have to run another wire through the firewall
Old Dec 24, 2009 | 02:48 PM
Shame on u C-hick,now u have to pretend to b suprised.
Old Dec 24, 2009 | 02:50 PM
Shame on u C-chick,now u have to pretend to b suprised.
aha ill still be happy as hell lol once i get it open its going on
lol but yeah ill do that tomorrow hopefully maybe next day because i forgot i need a few other things and napa or schucks arent open and i have ten minutes to get to the xmas party
Old Dec 24, 2009 | 02:51 PM
haha if i found out i got a winch for christmas i would be bragging too. how are you gonna mount it?
Old Dec 24, 2009 | 02:53 PM
it has a mounting bracket to it im not sure exactly yet i might build a bumper or use the mounting thing ill let you know more tomorrow haha
in the rear im gonna use the rear hitch mount too.
Old Dec 24, 2009 | 02:58 PM
sweet. good luck with that. if you lived anywhere near me id say lets hit the trails but...
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
steve miller
Oct 10, 2015 01:40 AM
luckypig44
Jul 19, 2015 11:25 AM
cars-guy
Jul 11, 2015 07:51 PM
skoti89
Jul 8, 2015 12:05 AM
