My power outlet plug in
DOESnt work. it hasnt worked for a year. it worked awhile back last winter it shorted out one day. but all my fuses are good. i cant understand it. its hooked up right my fuses are okay. anybody got any ideas??
trouble shoot, start at the fuse panel and if you have power there there is an issue between the panel and the outlet. check the plug itself, and the connections when i got my truck the power outlet didn't work and it ended up being that the guy before me had the dash apart and didn't put the wires back on there tabs.
also i am not sure on trucks and 4 runners but on my girlfriends 2000 corolla and the power outlet radio and clock where all on the same fuse.
or just wire up a new one.
Did you just run a power wire straight to it and a ground wire or what??
ya there should be a firewall plug on the pass side somewhere as for the ground could find a spot on the radio frame use a ring terminal and self tapping screw
I GOT A 8000K WINCH FOR XMAS. but im not supposed to know haha.
for the ground wire you can take off the side of the center console and any of those large 12mm bolts that go into the frame should work great for the ground wire. that way you dont have to run another wire through the firewall
aha ill still be happy as hell lol once i get it open its going on
lol but yeah ill do that tomorrow hopefully maybe next day because i forgot i need a few other things and napa or schucks arent open and i have ten minutes to get to the xmas party
in the rear im gonna use the rear hitch mount too.
steve miller
Oct 10, 2015 01:40 AM
skoti89
Jul 8, 2015 12:05 AM
