My power outlet plug in
DOESnt work. it hasnt worked for a year. it worked awhile back last winter it shorted out one day. but all my fuses are good. i cant understand it. its hooked up right my fuses are okay. anybody got any ideas??
Trace power and ground from the outlet to their respective sources. No easy way, just follow those wires!
Originally Posted by thedanned
(Post 51315248)
Originally Posted by DupermanDave
(Post 51315259)
x2 x2
trouble shoot, start at the fuse panel and if you have power there there is an issue between the panel and the outlet. check the plug itself, and the connections when i got my truck the power outlet didn't work and it ended up being that the guy before me had the dash apart and didn't put the wires back on there tabs.
also i am not sure on trucks and 4 runners but on my girlfriends 2000 corolla and the power outlet radio and clock where all on the same fuse. or just wire up a new one. |
don't use AC devices on a DC plug?
same thing happened to me. i just gave up and wired a new one. wired it straight to the battery and make it a full time outlet comes in very handy
Originally Posted by stockwell45
(Post 51315396)
Did you just run a power wire straight to it and a ground wire or what?? |
Thats what I need,direct power plug.Mine doesnt work either and the fuse is good.
Originally Posted by Matt90V6SR5
(Post 51315407)
use at min 14ga wire and a 15amp fuse
Originally Posted by Elton
(Post 51315419)
should i use a ground of anything or the fure make it okay?? |
ya there should be a firewall plug on the pass side somewhere as for the ground could find a spot on the radio frame use a ring terminal and self tapping screw
(Post 51315426)
I GOT A 8000K WINCH FOR XMAS. but im not supposed to know haha. |
for the ground wire you can take off the side of the center console and any of those large 12mm bolts that go into the frame should work great for the ground wire. that way you dont have to run another wire through the firewall
Shame on u C-hick,now u have to pretend to b suprised.
(Post 51315438)
Shame on u C-chick,now u have to pretend to b suprised.
lol but yeah ill do that tomorrow hopefully maybe next day because i forgot i need a few other things and napa or schucks arent open and i have ten minutes to get to the xmas party |
haha if i found out i got a winch for christmas i would be bragging too. how are you gonna mount it?
(Post 51315440)
in the rear im gonna use the rear hitch mount too. |
sweet. good luck with that. if you lived anywhere near me id say lets hit the trails but...
