90 4runner rubbing noise?
Old Dec 29, 2009 | 04:54 PM
sickboy13's Avatar
hello here' the low down. I have a 90 4runner v6 4wd. It is intermittently making a loud rubbing noise in the front right of the truck. It starts randomly and sometimes stops on its own or will start when I hit a bump,it will stop when shifted into 4wd, or when I brake or turn hard to the right. but happens only a portion of the time. took it to mech, he removed front drive shaft and said prob went away, it seemed the vacuum pump or the solenoid that activates shifting out of 4wd is defective. so he manually switched off the 4wd replaced the front shaft and voila!but on my way home the noise began again. super frustrated, 3rd mechanic in a week. any suggestions
Old Dec 30, 2009 | 12:25 PM
rattlewagon's Avatar
wheel bearing?
Old Dec 31, 2009 | 08:35 AM
sickboy13's Avatar
no not a bearing, a bearing noise would be a hum and get louder with speed. this noise onl occurs at lower speeds. I'm thinking it is something in the wheel assembly but don't know what.,
Old Dec 31, 2009 | 12:08 PM
Marc's Avatar
Do a search on spindle bushing. Common noise maker especially in winter.
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
