New 22Re dragging
Old Dec 31, 2009 | 07:01 PM
VANCE164's Avatar
New 22Re dragging
I Just Installed a new 22re long block in my 1988 toyota pickup. After I got the engine all hooked up it turned over about 6 times (never started but turned over) before the starter froze ( brand new battery and terminals) now with a new starter that has been tested and is good the engine drags turns over hard and isn't even getting to the point where it will fire. When it was turning over before the old starter froze their were no noises but their is oil in the throttle body and the oil smells like gas. I talked to the toyota master tech and he said the oil in throttle body is from the hose that comes out of the cylinder head into the efi which they say happens everyonce in awhile. But I still have no clue why gas would be in the oil although the other hose that goes to the cylinder head smelled badly of gas so im guessing that was why? Please help me I badly want to get my toyota project up and running!
Old Dec 31, 2009 | 07:12 PM
99 sas runner's Avatar
gas in the oil is probly beacause your rings arent seated yet. did a parts store test your starter?
Old Dec 31, 2009 | 07:20 PM
VANCE164's Avatar
yes i did have it tested before i brought it home and its still dragging? could it be something else bound up also the plate that comes out of the bellhousing for the clutch also got twisted but its straigthend out now and working properly could that possibly caused the clutch or flywheel to become bound up? and so its ok the rings havent seated?
Old Dec 31, 2009 | 07:55 PM
flyingbrass's Avatar
I'd try turning the engine over by hand using a long-handled wrench on the crank pulley bolt. That might help determine whether the issue is with the engine or the starter.
If this is the plate you mean, it shouldn't have moved or twisted.
Is your battery good? You said it's new, but is it actually good?
The rings won't seat until the motor runs.
Old Dec 31, 2009 | 08:01 PM
VANCE164's Avatar
no its the clutch I dunno if you would call it a plate its what the clutch release cylinder pushes to disengage the clutch. i can turn it by hand but its no super easy but not super hard I can do it with just a standard 19mm box end wrench. the battery is fully charged brand new from les schwab im a les schwab employee and terminals are brand new
Old Dec 31, 2009 | 08:34 PM
Ah, you mean the clutch fork. I don't see how the clutch linkage could cause the engine to drag, but if you want to test, press the clutch cancel switch and try starting (in neutral) without holding down the clutch pedal.
The engine turning over by hand is a relief. Not easy, but not super hard is normal.
Sounds like a bad starter, bad battery or bad ground. Ground seems like a prime candidate since you just hooked all this back up. Might clean off the negative battery cable end and block surface where it attaches. If that doesn't help I'd have the battery tested under load.
Old Dec 31, 2009 | 08:38 PM
VANCE164's Avatar
ok ill try checking the ground and see if that helps any and ive tired 3 other bigger battires that i knew were good. thank you for the input ill let you know if its the ground
Old Dec 31, 2009 | 08:56 PM
VANCE164's Avatar
flying brass your amazing! lol that was the problem sometimes im retarded, its turning over now to work on getting it to fire if your ever in the northwest hit me up ill buy ya a 30 pack!!!!
Old Dec 31, 2009 | 08:58 PM
abecedarian's Avatar
Did you build the longblock or is it remanufactured or used?
If you turn the crankshaft to TDC, which direction does the distributor rotor point?
Old Dec 31, 2009 | 09:06 PM
Glad I could help. Let us know how it goes from here. I'm half dreading the day I start my rebuild.
Old Dec 31, 2009 | 09:12 PM
VANCE164's Avatar
I bought a rebuilt long block so now i need to get the distributer lined out 100% properly but thats stuff for tomorrow so ill prolly be back for help and ill keep yall updated on how it goes hopefully its running by tomorrow afternoon!
Old Jan 1, 2010 | 07:13 AM
PirateMcgee's Avatar
you need to make sure you are getting oil on the cam before you start it.......
pull the valve cover and make sure oil is coming out when cranking it over
JNapolitano
Nov 14, 2019 07:46 PM
81Toy4x4
Sep 7, 2015 06:17 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
