Back-up light problem and solution
Old Dec 26, 2009 | 02:27 PM
cholbach's Avatar
First, thanks to everyone who posted advice to my problem. My back up lights worked intermittently, then not at all. I traced all the wires, cleaned the grounds, then was stumped. I discovered that my runner would not start in neutral either. Those two things together lead me to the neutral safety control switch. Once I pulled it off, I found that the inside was pretty dirty. Cleaned it out, then noticed that the contacts looked worn. Found out they both contacts have a small spring under them and the gunk had kept the springs compressed. Once cleaned and reassemble all I had to do was do a few adjustments and now I have back up lights and it starts in neutral.
Hope this helps someone else with the same problem.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
madxman21
Jul 9, 2015 10:26 AM
