Truck sluggish when going uphill
Old Dec 25, 2009 | 11:14 AM
clk_cpa's Avatar
My 88 runner is sluggish when going uphill between 3k-3.5k or when i really step on it . Before and after that rpm range its fine. When the road is perfectly straight or downhill it runs fine. Got new plugs, wires, cap rotor and fuel filter. Air filter is fine. What can cause this problem? THA
Old Dec 25, 2009 | 11:57 AM
Nogarage's Avatar
spark timing, valve setting, plugs, plug gap, coil, intake leak, exhaust leak, EGR, clutch slipping, air/fuel mixture. WHAT WAS CHANGED/replaced, adjusted just before you noticed your "sluggishness"?
Old Dec 25, 2009 | 12:30 PM
dakar652's Avatar
after finishing my motor swap (ended up installing a junkyard 22RE motor from a '94 in my '89 extra cab) i'm noticing that i'm still sluggish uphill too. prior to my motor swap i thought it was just the slop in the bottom end causing the problem, but now i'm thinking it might be more along the lines of either a partially clogged catalytic converter, or the crappy cap and rotor i put back on my distributor...but other than that, i can't see what the issue would be. i'll keep you posted, as i'm determined to reach the solution to my problem as my truck is a daily driver and i have a rugged commute in central/western massachusetts. let me know if you find anything on yours too!
Old Dec 25, 2009 | 02:04 PM
1990yota-pickup's Avatar
check the gap with a brass feeler gauge on the magneto inside the distrubutor. check the book but it should by .003 to .008 i think.. but its been sense august sense i looked in my hyanes manual...
you have to take off the cap.
then pull off the rotor botton...
then rotate the engine until you can get a mesarurment.. then measure away.. with a feeler gauge..
you should just need a phillps screw driver and a feeler gauge, That is brass.. you could use a steel one but good luck fight the magnet..
MadMax48
Jul 3, 2015 08:26 AM
Jake 85 sr5
Jul 1, 2015 06:49 PM
Paul H.
25
Nov 7, 2004 11:37 AM
Land yacht
Jun 28, 2002 09:53 AM
Corey
Jun 19, 2002 11:06 AM
