Please help, having trouble pulling E-locker 3rd
Old Dec 23, 2009 | 02:01 PM
JollyGreen's Avatar
I think the 2 long e-locker studs are rusted up.
The rest of the casing will barely seperate, but the part where the e-locker is, seems like it is still bolted in.
I have the elocker locked , the axles pulled about 4 inches on either side, and have pulled all the short nuts, and the 2 long nuts from the elocker.
Other than waiting for the wd40 to penetrate, does anyone have any suggestions?
Old Dec 23, 2009 | 02:56 PM
JonnyBoy's Avatar
Maybe a bottle jack under it, just enough to put some constant pressure on it, then a decent sized hammer and a block of wood. Sometimes it just takes a lil sudden force or the vibrations from striking it, even through the insulation of the wood.
Old Dec 23, 2009 | 03:47 PM
Stuwy123's Avatar
1. Take the brake lines and e-brake lines off.
2. Make sure the axles are pulled out all the way.
3. Make sure all nuts are off.
4. Grab a big flat screw driver or a prybar and try to pry the diff out of the axle.
Old Dec 23, 2009 | 07:17 PM
JollyGreen's Avatar
Got it!!
One of the actuator studs was rusted out really bad, all the other ones were fine.
Soaked it in wd 40 for 3 hours, and used an air hammer with a tuning fork to pop it off.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
