Reverse lights stopped working
Old Dec 25, 2009 | 02:16 PM
foskco87's Avatar
At first they would just flicker on and off while i had it in reverse and now they just dont come on at all. I highly doubt its the bulbs being out so it must be a relay or the switch in the gear shift? Has anyone encountered this before? Where do I start?
Old Dec 25, 2009 | 03:01 PM
myyota's Avatar
There is a reverse light switch screwed into the side of the transmission, check to see if the switch is working.
Old Dec 25, 2009 | 03:03 PM
tc's Avatar
tc
Check the bulbs first.
Old Dec 26, 2009 | 02:35 PM
cholbach's Avatar
Just finished fixing the same problem on my 86 runner. Automatic or manual??
Old Dec 26, 2009 | 02:39 PM
AzStorm's Avatar
What TC said.
I had this happen recently to my truck.
One brake/turn/tailight and one reverse bulb were out.
I replaced ALL the bulbs and all is well.Everything works as it should and I dont have to worry about the wife raggin on me about getting a ticket.
Bulbs are cheap and readily available at your nearest auto parts store.
Old Dec 26, 2009 | 02:52 PM
foskco87's Avatar
Ok thanks guys, ill check the bulbs first but if its not that its probably the switch. Im pretty sure its the switch because the lights would flicker on and off and basically just started being on less and less until they never come on. Oh and its a manual tranny.
Old Dec 26, 2009 | 04:17 PM
bain's Avatar
my old truck did that and the wires on the trans were old and coming loose
gillesdetrail
Nov 19, 2019 12:56 PM
camdenbuck
Jul 7, 2015 07:33 AM
aciorba23
Jun 29, 2015 04:18 PM
cchinny
Jun 25, 2015 08:11 PM
gog1968
Jun 22, 2015 05:55 AM
