Oil in 22RE intake manifold!?!
Old 03-18-2008, 03:51 PM
HelliphinoN8's Avatar
What the hell does this mean? Oil is puddled in all 4 intake tubes on the lower intake. The last time I drove it, it would studder when I'd give it more than half throttle. Any pointers would help, thx!
Old 03-18-2008, 03:56 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Means you're sucking in oil from the PCV and breather lines on the valve cover. That means blow by is getting into the combustion chambers and extinguishing a better part of your fire power. And, probably collecting on the plugs. Your intake plenum may also be clogged up.
Old 03-18-2008, 04:02 PM
ok that's what I found out thru googling it. So relacing the pcv valve should fix this prob??
Old 03-18-2008, 04:06 PM
thook's Avatar
You could try that....see what happens. If your not successful, you may need new rings......probably valve seals, too. That's a lot of blow by your getting.
Old 03-18-2008, 04:15 PM
Matt16's Avatar
Perhaps you rolled your truck and didn't notice?
Pull the valve cover instead of trying to remove the PVC valve with the valve cover on the engine. In all likelyhood, the thing will be cooked on pretty good and I had to cut the rubber grommet into peices then set it on fire to get it out. Its was really stuck in there because the rubber turned to something with the consistency of hard plastic.
Old 03-18-2008, 04:20 PM
thook's Avatar
Good idea, Matt16. It's not fun trying to clean the grommet out of the head.
Old 03-18-2008, 04:21 PM
myyota's Avatar
If your getting that much oil in the intake manifold then its probably time for a rebuild.
Old 03-18-2008, 04:23 PM
I already pulled the valve cover and it came off easy. I sure hope it's not blown. I'm tearing into it cause of a blown head gasket. It was getting hot in the winter and after replacing the whole cooling system, I figured it's gotta be the head gasket.
Old 03-18-2008, 04:25 PM
Matt16's Avatar
If your PVC was shot, your engine would run bad first of (worn PCV valve= vacuum leak). Oil could also leak out and into the manifold.
Replace the PCV valve, then see how it is, I would assume a rebuilt is in order just yet.
I'm serious about burning that bugger out. Its not easy.
Old 03-18-2008, 04:26 PM
Wouldn't it smoke if the rings were bad?
Old 03-18-2008, 04:29 PM
That could explain all the idle surging it was doing before I parked it. It was doing it at idle, and when I'd hit the brakes.
Old 03-18-2008, 04:35 PM
Matt16's Avatar
It would smoke if your rings were bad, yes. ALso, it doesn't explain why there was oil in the intake.
Old 03-18-2008, 08:46 PM
Thx guys, I'm gonna just replace the pcv valve and see what happens. The engine had good compression and didn't smoke so I don't think it's the rings. I'm not sure of the mileage cause the po replaced the engine with another used one and they threw is what they said was the odometer from the other truck which reads about 92,000 now. I'll keep you all posted on this.
Old 03-18-2008, 09:09 PM
myyota's Avatar
When was the last time you checked the oil ?, its not by any chance over filled with oil is it ?, that could cause excess blow by and it would get sucked into the intake.
Old 03-18-2008, 09:12 PM
ozziesironmanoffroad's Avatar
and remember, only put the reccomended amount of oil in, a car came in that was hydrolocked with oil. reason? woman put 25 qts of oil in the engine, (cuz it was too low, she couldnt see it from the place where you put the oil) (her words).
Old 03-18-2008, 09:26 PM
iamsuperbleeder's Avatar
wow... lol, funny you mentioned that. Believe it or not, I've seen this before at my work. A woman came in 3 times in about a 5 minute period and bought 2 qts of oil each time, and kept saying her car wasn't full yet. The fourth time she walked in, I figured something was wrong, so I told her that I would take a look for her. I unscrewed the oil cap and it was almost full to the rim! Odd thing was the dip stick didn't show anything... still stuck trying to figure that one out myself... but hey, although the loss of oil in the lower end may have made some noise, at least her rockers weren't going to be tapping
But def just try replacing that PCV valve first... after double checking your oil level...
Old 03-19-2008, 04:28 PM
Ha Ha funny. I'm not a woman! What I do is throw a V-8 sized oil filter on it and fill it up with 5qts. It's an old trick that I learned from an old guy that's the original owner of 2 trucks,....an '92 with 365,000mi., and a '87 that hit 489,000mi. Either of them ever required any bottom end work. It all works out. The dip stick reads right at the full line.
Old 03-19-2008, 05:35 PM
rajin's Avatar
also check the air filter. (if that is dirty, the engine will suck more from the PCV)
Old 03-19-2008, 06:07 PM
Cool. The air filter was just changed.
Old 03-28-2008, 07:30 PM
Good news. Well.... kinda. I got the head off and it was obviously a blown head gasket. Coolant was in the 3 rear cylinders. My question is, could exhaust gasses leak thru the blown gasket and go into the oil journals to cause a rise in the crank case pressure and throw oil into the intake??
Quick Reply: Oil in 22RE intake manifold!?!
