Is this the right direct replacement engine for me
Old Mar 11, 2008 | 02:50 AM
thekevin's Avatar
I have a 89 SR5 3.0 5 speed 4x4, I came across this auction and he states this motor is a 3vzfe, is this right, please take a quick look at this link and see if this will work for me before i buy it.
Link
Old Mar 11, 2008 | 04:41 AM
thook's Avatar
If yours came originally equipped with one, then yes. If not, then still yes. You'll just have to swap parts from his '88 to your '89.....like the ECU, distributor, wiring harnesses, etc.
Old Mar 11, 2008 | 05:30 AM
breknraj's Avatar
Do a search. I'm pretty sure that I've read that there are differences in the blocks in regard to the motor mounts. The 3VE-FE is from a front wheel drive car, and was mounted transversely. The intake and exhaust were radically different from the truck based 3VZ-E that came in your truck.
If you need to drop in a new engine, take a look in the engine swap section at the 3.4 conversion.
Old Mar 11, 2008 | 05:55 AM
thook's Avatar
That would mean the seller is incorrect about the motor then? He's selling a motor out of a 4rnr.
thekevin...
If what breknraj says is true and the seller labeled incorrectly, that motor would still work in your truck.
Old Mar 11, 2008 | 06:14 AM
rdlsz24's Avatar
You can see it's out of a 4Runner. The seller is just calling it a 3VZFE instead of a 3VZE. It should work.
Rob
Old Mar 11, 2008 | 06:50 AM
thekevin's Avatar
that is what i was looking for, i was hoping that he was just on the crack pipe and listed it wrong, which in reality for me is probably better because maybe i can buy it cheap.
voiddweller
19
May 2, 2016 09:10 PM
Alaskan91
Sep 21, 2015 04:39 AM
rbravo1
Jun 29, 2015 01:34 PM
Taz22R
Jun 21, 2015 04:44 PM
Old Red 94
Jun 16, 2015 08:32 PM
